Results 1 to 10 of 20
Thread: touchscreen no longer working? Lilliput 629GL-70NP/C/T-DVI 7" VGA Touchscreen w DVI
    Jun 2008
    DC Burbs
    Hi all,
    Not quite sure what the problem is... but I have this:
    Lilliput 629GL-70NP/C/T-DVI 7" VGA Touchscreen with DVI input
    It is brand new, and was fully functional using centrafuse.
    I took it out of the Lilliput housing and put it into my bezel bolt in kit.
    I then made the connections and turned it on. The touch screen no longer works.
    When I connect the USB I do hear the USB connected sound.
    I'm running Win 7 home premium on a mac mini (new) running Centrafuse as the FE
    Like I mentioned, this was working, I'm really confused as to why this wont work anymore when all I did was move the screen from the housing to the bolt in kit.
    I've even taken the screen back out to check to see if I tore any of the ribbon cables, but everything still looks good, secure, intact.
    is it possible to short out something and cripple the touch screen functionality?
    here's a pic....
    http://www.flickr.com/photos/9988333@N07/5632405133/
    Thanks for reading and your ideas.
    Jan 2008
    does it show up in your device manager, or in the touchkit taskbar icon?
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jun 2008
    DC Burbs
    hi soundman,
    it did show up in device manager and Touchkit.
    I even uninstalled and reinstalled the drivers and touchkit.
    it even said that it all installed successfully.
    i'm really puzzled as to why it still isn't working when all i did was move the screen into my bolt in kit...
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Did you use care with static electricity/magnetic screw driver? When everything is clean and tight, that's the only gremlim I can think of.
    Try to see if there isn't too much pressure from the bezel on the touchscreen. I would also try plugging it on a different computer. If it works, try another usb port on the original computer.
    You sure there's no other monitor connected to the macmini? Or was before that wasn't touch? I mean, suppose you had an HDMI screen to set up install, then later you connected the vga screen with touch on the vga output, etc. The computer might map things into a non-existent computer.
    Not likely, but I'm just throwing ideas out there.
    Jun 2008
    DC Burbs
    Hi Rippling, I did take care with static and grounded myself......
    I also took the whole thing out of the bezel and tested it without the bezel (with concern about too much pressure) and it reacted the same, meaning the touchscreen wont work. I also tried another usb port.
    there is no other monitor connected as well.
    i'm really confused by this...has anyone encountered this? i didnt see any threads.....thanks
    Jun 2008
    DC Burbs
    great, now all of a sudden the screen went bright.......no reason at all...
    looks washed out....
    i disconnected everything and will try again tomorrow.
    Jun 2008
    DC Burbs
    i found this...
    http://www.youtube.com/watch?v=noVnv...2FB911389B3513
    its a guy repairing a touchscreen via flame?
    i'm not sure i understand how this works..but i'm going to try it.
    Jun 2008
    DC Burbs
    ok i tried the flame fix.....it didnt do anything.
    i've reinstalled, uninstalled, reinstalled the drivers for touchkit over and over.
    and the touch screen still doesn't respond to touch??? WTF?
    i'm really at a loss here, what else can i do?
    Jan 2008
    probably replace the touch layer+controller...
    HID retro--100%
    Jun 2008
    DC Burbs
    Quote Originally Posted by soundman98 View Post
    sure, i'll try it, but i dont know what that is...can you explain?
  1. FS: Lilliput 7" VGA Touchscreen 629GL-70NP - $120
    By dpom77 in forum Classified Archive
    Last Post: 10-09-2006, 09:48 AM
  2. Lilliput 7" 619GL-70NP "versa" Touchscreen 629GL-70NP
    By flavor4real in forum LCD/Display
    Last Post: 10-05-2006, 08:00 PM
  3. FS: LILLIPUT 629GL-70NP 7" Touchscreen
    By Fraychild in forum Classified Archive
    Last Post: 08-14-2006, 11:34 PM
  4. For Sale Lilliput 7" VGA Touchscreen 629GL-70NP
    By sporty_drew in forum Classified Archive
    Last Post: 07-27-2006, 02:10 AM
  5. Lilliput 7" VGA Touchscreen 629GL-70NP - never used
    By manishie in forum Classified Archive
    Last Post: 09-09-2005, 02:09 PM
