Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Why LCD controllers are so big, so much thicker than the panel itself?
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    I've seen lots of interesting panels on the market today (right now I'm looking for 4-6.5") screen for my overhead console) but the controller boards are so much bigger than the LCD itself, it's laughable.
    It looks that controllers are stuck in 20year old designs (by comparison, check it out iPad's controller at iFix.com), with huge capacitors and wire link and the complete absence of "one chip" solutions...
    Case in point, Boe-Hydis 5.6 screen, 180degree angle; 1280x800; all I want to just mirror my desktop, but...:
    WTF? :roflol:
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Cost.
    Those cheap MIC displays are using off the shelf parts that are retrofitted to whatever EOL panel they buy.
    The cost to develop an AD board is not cheap. Plus, the smaller the footprint, the higher the cost.
    Dec 2007
    Danville, CA
    Well, I'd think that by now those off the shelf parts would have been gone 10 years ago (about the time CRTs passed away). I think they are still producing them in droves unfortunately, unless they made billions of them.
    ---------- Post added at 12:30 PM ---------- Previous post was at 12:26 PM ----------
    Quote Originally Posted by tft_lcd_org View Post
    Cost.
    Btw, I would have no problem with a digital only solution (DVI-D, HDMI, or display port, my tablet has one). I think that would make AD conversion unnecessary and the controller much smaller, no? Also cheaper, case in point, HDMI splitters were like $500 a couple of years ago, and you can find them now, HDCP ready and all, for $15-20.00...
    Meanwhile, HDMI to analog converters/splitter are still expensive.
    Dec 2006
    India
    The A/D board bundled with that screen comes from some legacy application and has too many features that you don't need...Ex. I can even see a TV Tuner.
    I've dealt with that ebay seller and he is quite responsive. Please ask if he has a smaller LVDS A/D board which could drive that panel
    Raw Wave
    Nov 2009
    Funny thing is SMD etc is cheaper to manufacture and more reliable etc - but that requires design (not copy) and investment.
    But if needing high connectors, why bother? And look at that pictured board - it has a tuner and double stacked RCA's. My Dog, it's so ancient it's even an analog tuner!
    Integrated can be made smaller than a freestanding entity.
    This year iPad. Next year - its controller.
    May 2010
    Detroit, MI
    Quote Originally Posted by DigitalVampire View Post
    Yes, he is quite responsive. But, JW only sells what he can connect. He does not program LCD controllers, so he can only provide what he knows will work.
    ---------- Post added at 07:00 PM ---------- Previous post was at 06:59 PM ----------
    Rip, What input do you want for a 4-6.5" display?
    Dec 2007
    Danville, CA
    I got an answer from him regarding a panel for the Samsung galaxy tab (7" but gorgeous). He said he has the controller, not the cable. Not a priority for me, but good to know. Still waiting on the other issue, what board can I connect to the hydis 5.6.
    tft_lcd, I'd like all the inputs possible, of course, but display port only would do. The best combo would be display port/one analog (vga or composite), that would cover all my possible uses, but display port should be fine, as long as it's smaller than most. What I don't like is boards with HDMI, DVI, VGA, component, composite...one digital, one analog should be enough, no?
    The thing with adding input options is the size of the controller board. I'd rather have cable extensions going into the board.
    I'm going to ask him if he can make something like a 12' cable from the LCD to the board (from the sunglass holder to the center console via A column), that way I could store that giant freak away somewhere and forget it even exists...LOL.
    Feb 2006
    Melbourne, Australia
    Hello RH,
    I am using the Digitalview ALR-1400 on my NEC custom transflective setup - nice and small, and not to expensive....
    See if you like it, and I hope the size is ok for you? Also nice, nifty cables you can get for it, decent vert/horiz button membranes, et al....
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    May 2010
    Detroit, MI
    Quote Originally Posted by mrbean_phillip View Post
    Hello RH,
    "130.00+ US is hardly "not too expensive..." for just an LCD controller.
    Feb 2006
    It's not just an lcd controller, go read the manual.
    Allows quite a fair few options, connectivity to different panels, et al. It works for me, and was worth the money, but may not be suitable for everyone - if RH likes it, good, if not, no worries As someone has mentioned, small footprint = pricy.....
  1. Replies: 3
    Last Post: 01-27-2009, 07:05 AM
  2. Replace Touch panel on my monitor? Which panel?????
    By gipsypilot in forum Input Devices
    Last Post: 02-01-2008, 02:31 AM
  3. Replace Civic 96-98 heater control panel with 99-00 panel
    By PredatorCoder in forum Fabrication
    Last Post: 04-24-2007, 05:14 PM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. LCD controllers
    By Christian in forum General Hardware Discussion
    Last Post: 03-26-2000, 01:11 PM
