Results 1 to 10 of 11
Thread: group buy on Sharp LQ104S1DG21 ...
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    I could get 10 of these for $75 a piece, would anyone want to get one? They are 350 nit and SVGA 800x600 res.
    Here is the datasheet...dataheet
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    Does this model accept the the Datalux M1023 controller card? And whats the viewing angle? I only skimmed over the datasheet and did not find it.
    If so count me in. If not NM.
    edit: Also do they include the backlight?
    Apr 2003
    HOT Arizona
    Hmmm. I assume they include the ccfls because it says 350 nits on the order site. I too have the datalux controller. This lcd has a 41 pin hirose connection, but looking at the datasheet, it has the exact same pins, just a few extra ground pins (10 extra to be precise). If anyone knows more than I do, please post!
    Apr 2003
    HOT Arizona
    I just compared the pinouts from my datalux LG panel and it is the same, there are just more ground pins that would have to be connected, thus a custom cable would be needed. Also, the datasheet says the ccfls are included, but no inverter.
    Aopen i855GMEm-LFS with Dothan 1.8ghz
    512mb DDR333
    Windows XPpro SP2
    I've got no answer! Question's Avatar
    Jan 2001
    Austin, TX
    I got an inverter for my LQ104V1DG11 from these guys...works, great.
    Here's the link for the dimming inverter or the LQ104S1DG21: http://www.milesie.co.uk/asp/product...?ProductID=355
    Keep in mind the pricing on their page is in pounds...should be 45 pounds (74.09 dollars...ouch) total (including shipping) to the USA (that was the price it gives me any way..)
    That's the only place I know to get this inverter...any one else want to post other places to get the inverter for this?
    It'd be nice to upgrade my 640x480 screen to 800x600 but I think that the controller I have (allenruble's datalux controller) is only 640x480 since it uses the 31-pin hirose not the 41-pin...oh well, about to check...but if not, hopefully this info will help the group buy.
    Constant Bitrate SinnerG's Avatar
    May 2003
    Long Beach
    I, myself, am interested. But reading through this, I question the compatability issues you brought up. Correct me if I'm wrong, but as long as the Panel voltage is correct, and the color data bits match from controller to LCD, then it should work, right? As far as the extra grounds go, couldn't you just connect one ground from the controller to the LCD, and split of jumpers to the other grounds on the LCD? Ground is ground.
    Feb 2003
    South Florida
    hmm good questions, So we would need to build a custom cable, the controller cannot and will not just fit in, like the sharp lq10d367? ????? will it work with the controller mentioned? hmmm
    Apr 2003
    HOT Arizona
    Good question about the controller resolution. I believe it's the timing that is the issue, not the color bit. If only Allen Ruble could tell us if it can support it....someone find out!!!!
    The ground (all of them) can be connected to frame ground, there is no worry about that.
    The inverter that fcc listed is for the LQ121S1DG31 not the lq104s1dg21. It may work, I don't have time to look into it, maybe fcc did....but the same inverter for the lq104v1dg11 should work, it's the same nits. There are some places in the US that sell them for $50. I was about to order one, I'll post info later...
    512mb DDR333
    Windows XPpro SP2
    Mar 2003
    I would be interested if/when the controller q's are answered
    Apr 2003
    HOT Arizona
    Or would you all rather have the Sharp lq104v7ds01? It is a 640x480 Transflective display. Beautiful for daylight apps but it has a narrower viewing angle. I could get ten of these for roughly $93 a piece. It is a 31 pin hirose and would accept the datalux controller directly.
    http://www.sharpsma.com/pub/productf...q104v7ds01.pdf
    512mb DDR333
    Windows XPpro SP2
