Results 1 to 2 of 2
Thread: removing scratches?
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    removing scratches?
    I am using a xenarc 8" TS I purchased back in 06, everything works perfectly, however it is covered in scratches. My question is there anything i can do to fix this? Ive noticed on the touch panel it has a thin plastic sheet with little pin holes over the glass, this is what is scratched, would the touch panel work if i removed it and replaced it with a screen protector? If not what would be a good solution to remove the scratches?
    Jan 2008
    you would probably need to replace the touch screen.
    you could try some polishing compound-- there is a chance it could make it a little better, but probably a better chance that it will make it worse..
  1. Eliminating Scratches
    By MKIV4EVER in forum LCD/Display
    Last Post: 06-08-2008, 01:36 AM
  2. how to remove scratches on a lcd
    By supramad77 in forum LCD/Display
    Last Post: 08-31-2007, 08:14 PM
  3. scratches on screen
    By godraj in forum LCD/Display
    Last Post: 12-12-2006, 09:37 PM
  4. Xenarc and Scratches?
    By Nutz in forum LCD/Display
    Last Post: 08-12-2004, 02:21 PM
  5. How do I get rid of scratches in my dash?
    By ShinkunoNamida in forum Off Topic
    Last Post: 11-11-2002, 11:54 PM
