Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: lines in 2nd and 3rd screen (RCA connected)
  1. #21
    Variable Bitrate nemo1's Avatar
    Jun 2006
    I did another test. This time I removed the RCA video splitter. So for this test the connection is as follow:
    com vga -> vga to rca video converter (power from dyi regulator) -> screens (RCA).
    I have a total of 4 rca screens. 2 at head rest and 2 in boot. I noticed that when I connect all 4 of them the screens become blur and flickers. So I connect 2 at a time and they are fine. No splitter box used just RCA Y cable splitter. When 4 connected I used 3 RCA Y cable splitter. The results seems to be better compare to using a splitter box with seperate power supply.
    I then connect 2 screens to the RCA output and 2 screens from the s-video output of the VGA to RCA/S-video converter and the results are better compared to connecting all four to only the RCA output. Anyone encounter this before?
    All the screens are powered direct from the car battery, if for the setup that I have will it be better if the power to the screens are taken from the M2-ATX? because I could still see some noise at the screens and after leaving it ON for a while it starts to blur and flickers a bit. Any ideas?
    Getting there.....appreciate all the replies...Thank You.
  2. #22
    Jan 2008
    it might be worth trying to power all the screens from the m2, though i don't expect it to improve much being that it seemed that most of your issues dealt with the voltage for the converter.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  3. #23
    Jun 2006
    Maybe I could try a low noise regulator....many thanks soundman98...
  1. Help with horizontal lines on screen
    By Slider1385 in forum LCD/Display
    Last Post: 07-18-2010, 07:22 PM
  2. lines on screen due to subs?
    By robhur in forum Car Audio
    Last Post: 02-19-2008, 06:08 AM
  3. Lines On Screen
    By thomen in forum LCD/Display
    Last Post: 02-27-2007, 12:24 PM
  4. once again the lines on screen
    By cambo in forum LCD/Display
    Last Post: 10-01-2006, 12:26 PM
  5. Lines on the screen
    By Juliemac in forum LCD/Display
    Last Post: 07-10-2005, 10:17 PM
