Page 2 of 14 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 133
Thread: Multi - Touch Capacitive Touchpanel with HID Controller + "Gesture Controlled Ouputs"
  1. #11
    Variable Bitrate m2x0p9x's Avatar
    May 2002
    Modesto, CA
    That was my next question, if you could do a custom size with the overlay. I believe my double din opening is 4.25" x 7.5". Unfortunately I just purchased another capacitive touch panel, and im really just interested in a the overlay. How does that work exactly, because I was under the impression your finger has to come in direct contact for it to work? Is it bonded to the touch panel or just sits on top?
  2. #12
    FKA CivicModz
    Mar 2011
    Australia
    Quote Originally Posted by stretch4x4 View Post
    Ah got you, sorry I read it as 2x 15V inputs as there were two.. oops
    So do you sell the glass already bonded to a monitor? or do we have to do that ourselves.. and supply our own monitor?
    I am also interested in the size as I need it to be a tad smaller than my double din spot.
    The tempered glass is already bonded to the touch panel, this then sits on top of you current LCD monitor like any other touchscreen. My small touchscreen controller then sits flush behind your LCD
  3. #13
    FKA CivicModz
    Mar 2011
    Australia
    Quote Originally Posted by m2x0p9x View Post
    The overlay (tempered glass) is already perfectly aligned and optically bonded with the touchscreen. It is bonded in a dust-free environment with no air-pockets in between the two substrates. So doing this yourself might be quite difficult without the proper equipment and materials.
    Even if you did want a custom overlay, you would have to specify a thickness that is recommended by your current touchscreen. So its not economically viable to have a different size/thickness for every type of capacitive panel. Also, my touch controller is only compatible with my touchscreen so it will not work with other panels.
    So a custom overlay for your particular touchscreen might prove to be quite expensive.
    I hope this helps
  4. #14
    May 2002
    Modesto, CA
    I see. How thick is the tempered glass in this setup? One of the reason's I got my new panel was because my old 3M one was so thick, and after attaching it to the LCD and bezel, the LCD was 1/2" deep making the image look farther away then it should. In the image above the glass doesnt look totally clear. Also can the right click function be disabled using windows XP? Thanks.
  5. #15
    Sep 2005
    Australia
    Thickness are as follows:
    Tempered glass : 0.7mm
    Capacitive panel: 0.6mm
    Total 1.3mm
    That picture was taken on a piece of paper, its 100% crystal clear
    With the right click function I can activate it by either:
    • Click n hold
    • Hold one finger then momentarily tap second finger
    • Or disabled
    If you have a custom request for right click, I could do that also. e.g "Swipe left in TOP region" with 2,3,4 or 5 fingers.
    Firmware is upgradable over USB so I can add it anytime
  6. #16
    FKA CivicModz
    Mar 2011
    Australia
    Ooops, I will try to be consistent and use my customGadz name from now on (Had some moderator issues for some reason).
  7. #17
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    So this will work as a direct replacement for the Lilliput. hmmm im interested
  8. #18
    FKA CivicModz
    Mar 2011
    Australia
    As noted in the specs this touchpanel has a 16:9 aspect ratio, but lilliput has 4:3. If everything you watch and do is in a 16:9 format then you wont have any cropping of the display. If you notice, when you are viewing at 16:9 on the lilliput you actually have a bit of the top and the bottom of the LCD not used.
  9. #19
    May 2002
    Modesto, CA
    As long as right click can be disabled should work ok. Thanks again.
  10. #20
    FKA CivicModz
    Mar 2011
    Australia
    The challenging bit is adding features, not disabling them.
    :P
  1. Finaly a 7" and 10.1" Multi-Touch capacitive touch overlay
    By davedave1234 in forum LCD/Display
    Last Post: 04-30-2012, 10:45 AM
  2. capacitive touchscreen with controller
    By afterdigital in forum LCD/Display
    Last Post: 10-03-2011, 10:24 AM
  3. Replies: 7
    Last Post: 10-01-2011, 07:23 PM
  4. New capacitive/multi-touch kits on the way?
    By SFiorito in forum LCD/Display
    Last Post: 11-11-2009, 06:15 PM
  5. Capacitive Touchscreen Overlay w/ USB controller
    By datdude31 in forum Input Devices
    Last Post: 11-01-2009, 07:50 PM
Tags for this Thread
