Page 3 of 14 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 133
Thread: Multi - Touch Capacitive Touchpanel with HID Controller + "Gesture Controlled Ouputs"
  1. #21
    Jan 2008
    i was interested until it became apparent that i would never be able to fit this into a double din frame...
  2. #22
    Variable Bitrate m2x0p9x's Avatar
    May 2002
    Modesto, CA
    I think the whole idea of having the finished glass overlay is too elminate the double din frame completely. Im using a Bybyte frame myself, but seems like everyone else is too. For me its nice too see something different, too bad I just upgraded other wise I would be very interested in this.
  3. #23
    May 2010
    Australia
    I was interested but it sounds like the glass and touch screen is not bonded is not bonded to the screen which would introduce glare..
    I also still need to buy my monitor so that is more cost..
    I was interested thought as it's in Aus so the shipping shouldn't be ridiculous for a change
  4. #24
    Newbie Seifer's Avatar
    Oct 2004
    Sydney, Aus
    Any idea on a price?
    My baby is done ...Go the soarer
  5. #25
    Jan 2008
    Quote Originally Posted by m2x0p9x View Post
    that's fine to eliminate the dd frame, but i still don't see how to mount this in the dd opening in a bolt-in fashion. i don't want to refab the opening, i want to keep a 'bolt-in' appearance, so idiots walking by don't think that there is a custom $1,200 carpc installed...
  6. #26
    May 2002
    Modesto, CA
    Sounds like you have had different experiences with the ByByte frame. Haha. Out of the 3 cars ive had them in, none of them were a direct bolt in.
  7. #27
    Oct 2004
    Sydney, Aus
    How would you mount this screen?
  8. #28
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Quote Originally Posted by customGadz View Post
    As noted in the specs this touchpanel has a 16:9 aspect ratio, but lilliput has 4:3. If everything you watch and do is in a 16:9 format then you wont have any cropping of the display. If you notice, when you are viewing at 16:9 on the lilliput you actually have a bit of the top and the bottom of the LCD not used.
    Maybe i misunderstood things.
    This is just the touch pannel and touch controller... correct?
    I guess i should have been a bit more clear. I use a transflective 7" lilliput bought from the mp3car store several years ago. Its probably a lilliput 619 or 629. Anyhow my touchpannel is starting to go and i have been checking out cost for replacements. Would this qualify as a replacement?
    And for the record this screen is not a 4:3, it's not even a 16:9... i believe its 16:8 technically but everyone calls it 16:9. The native resolution is 800x480
    What are the total L x W dimensions?
  9. #29
    FKA CivicModz
    Mar 2011
    Australia
    Yes, this is a capacitive touch panel with controller, that also has outputs that can be triggered by 2 or more finger gestures. So yes, it is a touch panel replacement/upgrade.
    Ok, so yours is a 16:9 that's good. I think you interested in the active area (88x151mm) this is section of where the LCD pixels actually light up. The size of the outer panel dimensions can be anything as I can get it cut to any shape. Saying that I will be posting up some pics of mounting options very shortly, so hopefully I can get some feedback and come to a decision of final glass panel dimensions.
    I'm putting a hold on cutting the glass tempered panels until I can come up with the right size that will please at least one person
  10. #30
    May 2002
    Modesto, CA
    I think it will be tough to get a size that will please everyone. But my double din opening is 111mm x 190mm. This size should work for most Honda/Acura's 1990-2003give or take a few models. Maybe check out what some of the more common or popular cars are on the forums.
  1. Finaly a 7" and 10.1" Multi-Touch capacitive touch overlay
    By davedave1234 in forum LCD/Display
    Last Post: 04-30-2012, 10:45 AM
  2. capacitive touchscreen with controller
    By afterdigital in forum LCD/Display
    Last Post: 10-03-2011, 10:24 AM
  3. Replies: 7
    Last Post: 10-01-2011, 07:23 PM
  4. New capacitive/multi-touch kits on the way?
    By SFiorito in forum LCD/Display
    Last Post: 11-11-2009, 06:15 PM
  5. Capacitive Touchscreen Overlay w/ USB controller
    By datdude31 in forum Input Devices
    Last Post: 11-01-2009, 07:50 PM
Tags for this Thread
