Written the pm just finding the pics right now![]()
OK, no problem. Some pics will be good too![]()
Quad-Core JellyBean headunit... WTF!
MimicsX2 - Whats your flavour ?
OK, so I now possibly need to make the following sizes:
111 x 190mm - Most Honda's (4" x 7-1/2")
98 x 173mm - according to my Metra kits
If you know your standard dash opening and it is not these sizes please let me know.
I need something that fit the exact size of the 7" lilliput
Can you give me dimensions, as I'm not sure if you going to use it inside a or some other frame. I think your referring to the LCD size.. Correct?
Correct. I will use it inside a motorized housing where real estate is at a minimum. However as long as it will is no larger than the LCD panel I am good.... i.e. exact size of a 7" Lilliput touch panel replacement like the ones you can buy at the store. I dont think thickness will matter so much. Just length and width. I will try to get you some exact dimensions
Some maximum dimensions allowable for this to fit in your case will be great. At the moment I'm considering 100x178mm for the glass overlay. The problem that if you use my panel with a lilliput LCD you will lose 1.5mm from the top and bottom of the LCD as my touch panel is widescreen format. I do however have an LCD that will suit my touch panel that is slightly smaller than the lilliput. Not sure if you are willing to have a my LCD to suit. I plan to have the glass, overlay and touch panel optically bonded with each other to reduce reflections. If you get the touch panel on its own you wont have that optical bond as the touch panel will be simply sitting on the LCD not bonded.
I will have an optically bonded one thanks![]()
When do think these will be available?
