Results 1 to 3 of 3
Thread: Need Help Wiring..
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    Question Need Help Wiring..
    Hi guy i need help wiring from hyperion controller to ERgpower inverter..
    Just incase u need this is i have hyperion Simplicity series controller
    Sharp 10D421 Lcd and Ergpower D12KM60J inverter.
    This is a plug is: J2 Inverter Interface Connector.
    pin name Function pin Name function
    1 Pwr +12Vdc Inverter 2 PWR +12Vdc Inverter
    3 GND 4 GND
    5 GND 6 ON- Alternate TTL ON/OFF
    344 0=ON=Full Bright, 1= off
    7 Gnd 8 ON Alternate TTL ON/OFF
    1=ON=Full Bright, 0= off
    9 VCC +5Vdc inveter 10 BRT 0 to +5VDC Backlight -
    brightness
    This is the inverter input cable: Inveter is ERgpower D12KM60J
    J1-1 Vin(+)
    J1-2 Vin(+)
    J1-3 GND
    J1-4 GND
    J1-5 Control*
    J1-6 NC
    J1-7 NC
    J1-8 NC
    * Valid WHen the "C" Jumper is removed.
    I just need help by knowing what wires to connect. Please help if you
    know how to do it. Thank you. oh ya you can email me at [email protected]
    Thank you agian
    May 2003
    Florida
    If this is hard for you to understand just email me.. i can send you pdf for both of those things. thank you
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Send the PDFs
    Aopen i855GMEm-LFS with Dothan 1.8ghz
    512mb DDR333
    Windows XPpro SP2
