Can I replace the touch screen or do you mean the whole display. Mine already has a changed out touch controller. BTW... no too much help from MOCOSO anymore.
Printable View
What is the likelihood that it is because of the USB cable/connection? I notice the connection can be jiggled around a bit.
if you have already opened the case(voiding the warranty) then you can try to sand down the area where the screen mates to the bezel to get rid of the high spot that is causing the issues.
Hey guys,
I also have a MT700 touch monitor, with the same haptic touch issues. Randomly, the screen will start pressing the top right corner, and then cease to register any touch input. The only way to fix it is to trip my main power circuit breaker that powers my CarPC, audio amps, and HDRadio. Did you guys ever solve this issue? It's only getting worse and worse with my unit. I'm about to give up and get a resistive Lilliput.
I believe it was the bezel. In the end I just gave up on the POS and went with the Lilliput.
