Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Weird problem on Mini Touch 700
  1. #11
    May 2011
    Can I replace the touch screen or do you mean the whole display. Mine already has a changed out touch controller. BTW... no too much help from MOCOSO anymore.
  2. #12
    Mar 2011
    What is the likelihood that it is because of the USB cable/connection? I notice the connection can be jiggled around a bit.
  3. #13
    Jan 2008
    if you have already opened the case(voiding the warranty) then you can try to sand down the area where the screen mates to the bezel to get rid of the high spot that is causing the issues.
  4. #14
    May 2011
    Quote Originally Posted by tft_lcd_org View Post
    Both of you (kammeroo7 and bchiang) seem to have the same problem: defective touch screen.
    Yep! Got one off ebay and wadda know... works like a charm. No thanks to MOCOSO.
  5. #15
    Oct 2011
    Hey guys,
    I also have a MT700 touch monitor, with the same haptic touch issues. Randomly, the screen will start pressing the top right corner, and then cease to register any touch input. The only way to fix it is to trip my main power circuit breaker that powers my CarPC, audio amps, and HDRadio. Did you guys ever solve this issue? It's only getting worse and worse with my unit. I'm about to give up and get a resistive Lilliput.
  6. #16
    May 2011
    I believe it was the bezel. In the end I just gave up on the POS and went with the Lilliput.
  1. weird issue with touch screen
    By scottwarney in forum LCD/Display
    Last Post: 05-12-2010, 12:07 AM
  2. WEIRD Lilliput 10.4" touch screen problem
    By bambam in forum LCD/Display
    Last Post: 04-30-2007, 10:34 PM
  3. help touch sreen all weird
    By Flexia in forum LCD/Display
    Last Post: 01-09-2006, 10:51 PM
  4. Weird Weird Weird Holux 210 problem
    By omernesh in forum GPS
    Last Post: 07-01-2005, 09:55 PM
  5. My touch screen Controller acting weird.
    By SilentAdmirer in forum Input Devices
    Last Post: 06-15-2004, 09:24 PM
