psone lcd works,but 8 bit?
i finally got the screen to work off of vga,but am i to understand that everyone who has done this is running the screen at 8 bits per pixel/256 color?this is the only way i have got it to work anyway.
My one runs at 32 bit with no problems.
What are your powerstrip setting?
if you could post screen shots of the setting that would help alot
Also did you use my diagram or starfox’s?
i used starfox's diagram with your powerstrip settings(mine is the sony ntsc lcd,my video card is a rad 9000pro w/comp sync).ill have to reconnect evrything real quick and then ill post settings.thanx 4 listening
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
