Happened to me as well. Turned out to be the white ribbon that connected the board to the screen. I would make sure you did not hit the input button and check the connections.
So I've been setting up the software on my Lilliput for a few days to get it perfect before I put it into the car. Today I go to use it and there's no display. Not even the "No Input Detected" blue screen that I'm used to seeing. The power light is red and I can turn it on to make it turn green but no dice.
I opened it up and all of the connectors are in securely, so I'm not sure what it could be.
Any ideas?
I have an FA-801 so it's a bit different under the hood. Below is a picture of the ribbon I'm dealing with, the left side looks a bit warped compared to the right. I have removed and reinserted them to no avail. Any idea where I'd find a replacement like this?
