Originally Posted by
Auvee Bloomberg
I have the $136 ebay transflective screen, and it works fine, until I mount it to the double din enclosure (bybyte) The only way I can describe what happens is by saying that it's like there is an extra finger on the LCD whenever I try to use the touch screen. It's not as accurate as it is when it's not mounted in the double din enclosure. This is probably because a part of the lcd is touching the double din unit....
I'm sure some of you have dealt with this, how did you address the issue?
