Touchscreen problems
Got a new motherboard/cpu combo, memory and SSD drive, but since installing my first unit I have lost the driver cd for my touchscreen. I have found 2 threads on this forum with drivers for my touchscreen but after installing either of them, the screen still does not respond to touching.
This is the screen I have:
http://www.gooddeals18.com/product/S...reen--VGA.html
I'm sure it is something I'm doing wrong at this point, but after 3 days of hardware issues at work, I'm tired of dealing with problems.
This thread has both of the drivers I have tried:
http://www.mp3car.com/lcd-display/10...s-monitor.html
Everything appears to install, so I restart and try to do a calibration. On the calibration is where it doesn't respond to touching.
Any ideas?
When you plug in the usb, do you hear the Windows usb notification sound? Do you have a touchscreen/hid-compliant entry in keyboards (or mice and other pointing devices)?
Have you tried the older versions of the cartft drivers, or did you just try the newest ones?
Yes to all of the above. The oldest drivers I tried were 4.3.8.
I know it isn't the screen as I can hook up the old harddrive and everything works.
FIXED: I had to rollback all the way to the 4.0 drivers.
Hook up the other drive and connect the screen. Look in the device manager and find the device(s), then look at the driver section and find out where the drivers are. Copy them and paste them onto the new drive, then point the screen at the copied drivers and see if things start working. Plus, you can also google for the driver names you find and see if you can locate the drivers online.
You might want to contact the company you bought the screen from, and ask for the drivers.
Have you checked out this site?
http://www.touch-base.com/
There's a thread on this forum about drivers for your screen, and he found them at touch-base.
kegobeer, I tried copying the drivers from the old drive, but they didn't work.
After finally getting the 4.0 drivers to work, the screen has to be calibrated each time before it will work. Any ideas? edit: missed the 4.3.0 drivers the first time. After getting those everything works as it is supposed to.
