Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
Thread: Lengthening LCD lines...
  1. #31
    Constant Bitrate captain_jim1's Avatar
    Nov 2002
    New Jersey
    The laptop booted fine before the mod .. and now it POSTs .. pauses right after it detects the HD, RAM, etc ... then goes into Windows... Don't think any other connections will have done this.
    If I unplug the new cable I've made from the mobo it boots up regular speed ... nice and fast. I can tell from all the HDD activity. So weird.
    Oddly enough, the battery on the laptop doesn't seem to work anymore either. It used to hold a small charge, but now it doesn't hold any. Just happened suddenly .. think maybe something on the mobo is doing this?
    Thanks..
    -Capt.
    -Brad
    83 mp320i
    99 mp323i
    _________
    7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
  2. #32
    Nov 2002
    New Jersey
    We drying up on ideas?
  3. #33
    Jan 2003
    Ruston, LA
    Sorry you're in the same place as your avatar
    I don't have any more ideas
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  4. #34
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Same here. Would love to be able to offer assistance, but best I could manage was the foil shielding that got you this far. I know that can make a difference, because a guy at work used it to repair a 21" CRT because a thief had cut the cable clean off when they broke into the office, stole the base unit, but left everything else.
    4x4 in a turbo stylee.
  5. #35
    Low Bitrate theedge's Avatar
    Apr 2003
    Vancouver, BC
    Replace the battery. When the computer first boots up, the BIOS detects all the settings (com ports etc etc), then boots. The battery is there to keep the information in a chip called the CMOS so the next time you boot all the settings are there. Dead battery = computer has to redetect each time, thus some lag.
    Thats also why it boots fast when you do a straight restart, no power down.
    As for booting quick when LCD is unpluged... take a multi meter and test the battery when the lcd is plugged in and not plugged in. Maybe something funky is going on...
    Thats all I can think of ATM.
  6. #36
    Nov 2002
    New Jersey
    I don't believe the CMOS battery is dead.. just the regular laptop battery. I doubt this would have the same effect. I've also noticed that if the system is warm, but I'm still doing a 'cold boot' .. (not a restart) that it'll lag, but for not as long as when it's a cold systme (hasn't been on for a while)..
    -Capt.
  7. #37
    Apr 2003
    Vancouver, BC
    Ahhh I thought you were talking about CMOS batt.
    Does it run different when youre using the AC adapter?
  8. #38
    Nov 2002
    New Jersey
    Hahah yes it does .. it runs ... for some reason it won't charge the battery or boot off of it (prolly cuz it's dead) .. only runs on the AC Adapter... oddest computer ever...
    -Capt.
    -Brad
    83 mp320i
    99 mp323i
    _________
  9. #39
    Apr 2003
    Vancouver, BC
    -Capt.
    Time to buy a new battery Hope you have lots of $ to spare.
