Results 1 to 4 of 4
Thread: tm-701 question
    Jun 2003
    tm-701 question
    I have a question for those out there with a tm-701. I just got one and am having some difficulty getting it to actually get a signal from anything. I orignally tried it with my x-box then a dvd player and a vcr finally i gave up trying. I did not splice a composite cable an put a 75 ohm resistor in and try that yet because i didn't have one laying around, and i wanted to see if this is a common problem/occurance with these monitors. any help would be appreciated.
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    Re: tm-701 question
    Did you order it from us?
    If you're powering it correctly (12V DC) you shouldn't have any problems. Also you don't need a resistor to use it with a DVD player, VCR or a Game console.
    What exactly is going on when you turn it ON?
    Armen
    Jun 2003
    armen,
    yes i did order it from digitalww. as to what it is doing. I have a clean 12v dc power line running to it. What is giong on is i have it plugged into the power. i have the composite plugged into dvd/vcr/etc.... i then press the power button on the screen or remote (both do the same thing) it powers the screen on for about 1/2 to 1 second and flashes it white. then it powers down. I know a signal is running to it because if i pull the composite going into it and plug it into a tv i have sitting there it works great. I have tried with both inputs and they both do exactly the same thing. Any ideas on what could be going on would be greatly appreciated.
    thanks
    Sep 2002
    ILLINOIS
    Email me and I'll take care of it.
    Armen
