Results 1 to 4 of 4
Thread: Lilliput EBY701 Issue - Reverse Y
    Jul 2009
    Squamish, BC
    I have an EBY701 which arrived working great. Last time I worked on the enclosure it was necessary to separate the ribbon connector between the board and screen. I was very careful not to crease or bend anything. Now that it is back together the Y axis (only) is inverted.
    I have tried to reseat the ribbon a few times. It is snug in the connector and always returns the same results. Screen looks great apart from the Y axis being inverted.
    Is there a setting to correct this?
    Could it be the cable is broken (if so, where to get a replacement)?
    Jul 2009
    Squamish, BC
    I forgot to add that I also put on a screen protection film.
    Jan 2008
    have you checked your video card output on your pc? some graphics chipsets have hot-key's for screen rotation's, so it could have been done inadvertently(i have done it more then a couple of times with intel integrated chipsets)..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jul 2009
    Squamish, BC
    I just fixed it.
    Although I disconnected the ribbon at the PCB end. It was the connection at the other end that was bad. With a little bending and adjusting the screen flipped back to ok. I also managed to get the screen reinstated in the box without any problem.
    I recommend that you do not remove the ribbon cable EVER!
  1. Replies: 1
    Last Post: 10-13-2011, 08:29 AM
  2. Lilliput EBY701-NP vs. Lilliput 629GL-70NP
    By BenKenobi in forum LCD/Display
    Last Post: 04-06-2010, 12:55 PM
  3. How to reverse image on Lilliput EBY701?
    By tmnt in forum LCD/Display
    Last Post: 05-24-2008, 12:11 AM
  4. EBY701 Touchscreen issue
    By ContaiN in forum LCD/Display
    Last Post: 03-29-2008, 10:03 PM
  5. Lilliput reverse image?
    By CDesigns in forum LCD/Display
    Last Post: 05-13-2004, 01:14 AM
