so when you switched it to the standard vga connection it worked? then that means that you need to connect it with the hdmi cable.
the preferred method for longer distance wire runs is to install the lilliput-supplied break-out cable on the screen, and then run separate usb and hdmi cables back to the pc location.
LinkBack URL
About LinkBacks
