Results 1 to 10 of 10
Thread: my LCD Mount is complete!
    Sep 2002
    Worcester, MA
    I spent all day trying to figure out how i was going to mount my LCD to my old radio so i could use the frame. After about tossing out my old idea, and a few others I came up with today, I sat down with my dad to come up with some ideas that would have minimal damage to the LCD or its case so I could remove it easily, and reuse it in the future.
    This is the end result. It slides in the din slot perfectly because it uses an old factory radio frame. The electrical tape was to cover up some sharp edges, and to make sure nothing accidently shorts out.
    Im pretty happy with how it looks/came out. I have it sitting next to me on the desk with now hooked up to my stereo so i can get used to the controls and get it ready for the install. All i need now is an amp to hook up to the speakers, and the opus.
    Mar 2003
    Gainesville, FL
    cool. . .. im still waiting for my screen in the mail
    2003 Mazda Protege5
    Molded Xenarc touch Screen
    Via M10000, seagate 40gb, 16x laptop dvd, RS gps
    EDAC 55w dc/dc
    homebrew shutdown controller
    2 power acoustik 10 FUBR's, A1800DB mono amp, AH600 to power mids and highs, pioneer speakers
    Jan 2003
    Ruston, LA
    that rocks
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jun 2003
    Hehe I had a different approach... I took the screen apart and mount it into my dash. There goes the warranty =P
    Sep 2002
    Worcester, MA
    I tried taking the screen apart, but when i removed the back plate and then the front, i knew it would be MUCH harder than i wanted it to be, and odds are, i would have probably broken it .
    Apr 2003
    DC and Dayton, Ohio
    mount
    Very nice install. I am thinking of doing something similar but I am struggling with exactly how to. Can you explain how you were able to attach the screen to the radio housing??
    Sep 2002
    Worcester, MA
    I got some 1/4inch thick wireties from home depot, and used the screw holes which attached the back of the LCD and screwed the ends down. You can kinda see that in the first picture here. I ended up flipping the screws around, but its the same basic idea. I put one at each corner. Inside of my radio thing there was a cross beam that was about 1/2 up and only an inch wide. I just used that as the anchor and secured each tie to the one diagonally across from it. I then ran the power and video cables in, tieing those down in 3 diff locations so they couldnt get accidently ripped out or come loose. It holds it VERY secure, and it didnt require me to destroy the original casing, so i could take it apart and put it back together in the future.
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    Is that LCD VGA or tv resolution?
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    That would be the famed 7" vga lcd.
    -Nick
    _____________________________
    www.mp3vw.com
    Sep 2002
    Worcester, MA
    yep, its the 7inch LCD from dscustoms.
