Results 1 to 4 of 4
Thread: lilliput touch screen not accurate & only works for a few minutes?
    Oct 2009
    having a a weird issue with this new carpc i have. I installed all the touch drivers and the touchscreen works fine on the bottom of the screen but as I go up the screen it gradually reads my touch higher than what it is. to press the top of the screen, I have to press about and inch down. I've calibrated and still nothing. Also, the touchscreen stops working after a few minutes, not sure if its a USB issue but it works for literally 5-10 after start up and then wont work until I restart the PC
    what gives?
    TIA
    Jan 2008
    have you tried the screen on a different pc?
    Oct 2009
    not yet, it's installed in the car right now and kind of difficult to remove for theft reasons, but I'll get around to it tonight to double check and report back.
    any suggestions on what may cause it though?
    Apr 2005
    I have the same exact issue with my lilliput and if my memory serves me right I remember reading a year or 2 ago that someone said the issue was the touch panels glue was failing.
    I think they took a heatgun and removed the TS panel then re-did the adhesive and it fixed it.
    Try searching the forums, because when I looked there was quite a few threads on it.
    I had thought about doing it to mine, but the connection for my ribbon cable is TERRIBLE and a hella pain in the *** to get it seated correctly so I didn't want to mess with it again.
  1. Lilliput FA1012-NP/C/T 10.1" LCD Touch Screen Monitor With Multi Touch DVI HDMI Revie
    By jake5253 in forum MP3Car Products - store.mp3car.com
    Last Post: 05-26-2015, 11:04 AM
  2. Replies: 3
    Last Post: 01-15-2011, 09:25 PM
  3. Touch Screen isnt accurate!
    By cambo in forum General Hardware Discussion
    Last Post: 11-07-2007, 08:38 PM
  4. Lilliput screen works but touchscreen doesn't
    By JohnChimpo in forum General Hardware Discussion
    Last Post: 02-16-2005, 12:00 AM
  5. lilliput touch screen Vs Xenarc 7" touch screen
    By Fear Effect in forum LCD/Display
    Last Post: 10-18-2004, 01:39 PM
