Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Lilliput touchscreen hdmi, confused
    Dec 2007
    NY
    The lilliput 669 hdmi has a usb at ONE end. I don't understand this, what is that for and which end does it plug into. I need to buy parts and haven't connected it yet, the shop is doing it today so I don't have the setup in front of me, but I keep processing it through my mind and it doesn't make sense to me.
    I assume I have to connect the main harness with the vga connector since that connects to the sks cable which I assume that I have to use regardless if I'm using the hdmi or not. So if the main harness has the usb connector, what is this for? Why does it only have a usb on one end? What about the other end? How is that suppose to work?
    Or am I just overthinking this and I just connect the HDMI/USB connector end to the computer and the HDMI only end to the monitor and get rid of the sks connector?
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    The USB is for the touch-screen portion of the monitor. SNO
    Dec 2007
    NY
    I get that part, but trying to make sure about the other end, where is the other end of the usb?
    Nov 2009
    Keswick,On Canada
    the single hdmi end with the usb branching off it goes to the monitor. the other end with only hdmi goes to computer as well as the usb to computer. the usb gets to the monitor via the hdmi plug thats why the 2 cables to one plug at monitor. Hope thats clearer as its hard to explain via text SNO
    Dec 2007
    NY
    I'm sorry, that doesnt clear it up at all...at least to me. The way you worded that indicates both ends have usb, when in fact only one end does.
    Quote Originally Posted by SNOtwistR View Post
    That indicates to use the usb on the monitor end, but there is no usb conector on the monitor. Just the hdmi/sks/power. Does that mean plug in the sks jack, and plug the usb into that?
    That also indicates to use the usb on the computer end. But if i do, how is the touch communicating with the monitor?
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Champak,
    What SNO said was that the end WITHOUT the visible usb connection connects to the monitor -- this end has the usb line embedded inside it. The other end connects to your HDMI port and a USB port (for touchscreen).
    So yes, there are USB connections at both end -- just one side is embedded into the wire.
    Nov 2009
    Keswick,On Canada
    Maybe this will clear it up excuse the stick drawing SNO
    http://twintower.homeip.net/cable.jpg
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    This should clear things up:
    SNO - your drawing is a masterpiece, mine is a stick drawing! lol
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Dec 2007
    NY
    OK thanks for your help. I actually asked a few people today if this was possible so I wouldn't waste everyone's time, and everyone was adament and said "you can't do that with HDMI." Funny when everyone has the definitive answer it's always wrong lol. Hopefully everything will be up and running later.
    Jan 2008
    that just makes it more fun to tell them that they're wrong
  1. lilliput 669 hdmi rv
    By Kazimir in forum LCD/Display
    Last Post: 11-25-2011, 04:48 PM
  2. Replies: 25
    Last Post: 10-07-2011, 12:12 AM
  3. Need lilliput HDMI/USB cable
    By phantomfsoc in forum LCD/Display
    Last Post: 02-15-2011, 09:07 PM
  4. Replies: 4
    Last Post: 02-09-2010, 07:43 AM
  5. hdmi touchscreen
    By tripzero in forum General Hardware Discussion
    Last Post: 12-19-2009, 08:11 AM
