you could try to either add some diodes in-line with the wire, or possibly try a 1k ohm resistor to reduce the surge..
hi,
i have lilliput 629 with trigger cable for reverse cam. it was running perfect for couple of months then it start to trigger when i brake.
however there is little impulse when i brake so it goes av and back to pc simultaneously for once. i guess i have problem with my trucks taillight. i will solve it next service day.
during this period, iwant to make a delay circuit that eliminates the impulse from the brake light. i ve googled some and find a circuit with rc,relay, diode.
it is little complex for me so i wonder if i can make delay with simple rc circuit.
My 2001 Mitsubishi Eclipse GT:
"The Project That Never Ends"
more projects then time!
Led Skyline Tail Lights--100%
High Power Led Reverse Lights--100%
Led third brake light--100%
Led front turn signals--0%
HID retro--100%
Where did you connect the wire itself? to the reverse lights or the reverse switch itself??
This should not be happening unless your getting a cross feed or something happening, I would disconnect the monitors wire and reconnect it just to check/test as could be a something simple that is causing it.. Then wire it up with either a relay or something.. Also have you fused that wire? I know some people dont like to... but some have learnt the hard way by not doing so.
2004 Holden WL Caprice Auto GENIII
Base PC = Installed
Front End = In Progress 75%
OBD2 Interface = Installed / V2 Due Soon
Realworld Interfaces = In Progress 20%
Internet Linking = In Progress 10%
Voice Control = In Progress 35%
i remember seeing this issue before, i believe that most solved it by installing a relay to trigger the the reverse wire..
it is just part of integrating with the cars wiring-- some cars are just funky like that..
HID retro--100%
I can understand some vehicles are just ... well not common sense wired..
but to have a vehicle where the brake itself triggers the reversing circuit? That would mean in mine things like the mirrors adjusting to a pre set for reversing any time i tap the brakes.
So by using a relay it would be counting on the relays switch time? just seems a little uneasing that it would work in that way... But such is technology
Base PC = Installed
It's often connections - the increase resistance hence higher voltage spikes (despite less current).
R&R'ing connections and bulbs etc often fixes the problem till next time.
Hence why many prefer using a relay (using fused power from the battery),
HID retro--100%
Ok, so the issue at hand is more the actual signal wire vs the vehicle itself.
Base PC = Installed
i would say it is half-and-half..
the lcd shouldn't be that sensitive, and the car shouldn't be outputting any amount of voltage on that wire unless you are shifting past reverse..![]()
HID retro--100%
thanks everyone for your answers
i had the wiring done by the one who setup my rear camera. so when this occurs i re check the wiring if there is leakage or sth. it is connected to reverse light wire near the camera. but it is not the wiring.
first i will try resistor if not, i will connect small button to my gear knob so i can change the screen when i need reverse cam. i dont need it everytime and since my truck is automatic i have to select R when going from P to D.(in my opinion the tiny relay like thing in my controller board had burnt because of too many on and off)
