Liliput 669 no longer powers on after sleep
I tried searching the forums but i haven't found a clear answer. I'm not sure if i'm using the correct terminology.
I had this working for aout year and a kick myself for breaking a cardinal rule of: no touchee if workee.
Got a Lilliput 669GL-70NP/C/T-HB-RV HDMI DVI High Brightness, preassembled, notebook Atoms proc. running vista, Centrafuse 3 with a carnetix p1900. I installed the 5 volt PS for a powered USB hub that attaches to the carnetix. after all the faults that started happening, i got everything back up and running BUT, now when the system goes to sleep on ignition off, the monitor dies off instantly. More frustrating, the monitor no longer comes back on upon ignition on and i need the remote to turn it on.
In the past, when the ignition goes off, the monitor would going to sleep with the computer, and not shut off abruptly. it also did come back up.
Things i've done/checked:
The computer does shut down gracefully when the ignition is off as well as power on so it's not killing power, but sleep signal is coming from the power supply.
jumpers are set to sleep on JP1 on the power supply.
Verified sleep is set to centrafuse and windows.
Checked all connections.
This happens whether the 5 volt ps supply is connected or not. In otherwords, i reverted back to my old hardware configuration.
Things that happened along the way:
Battery negative was disconnected so all juice was removed from vehicle.
Lost touch function for a bit. I found out the USB in the HDMI cable wasn't connected all the way.
It comes down to, i have no idea what i did. When i originally did this project last year, a buddy of mine was the subject matter expert and if he did something, i can't figure it out.
