Results 1 to 3 of 3
Thread: Xenarc 700TSV - Issues with VGA signal
    Mar 2006
    I've got a Xenarc 750TSV and now that I've finally installed it in the car, I'm having issues with the signal. The PC boots and the monitor does nothing. If I wiggle the VGA cable a bit the monitor will eventually turn on and everything is fine. Once I shut the car off and start it again, the signal isn't found. I'm hoping the issue is just the VGA cable and not the lcd itself.
    I even tried powering the screen using the standard plug instead of the car and the problem persists.
    The real issue is that once I put the car back together, I can't get at the cable to wiggle it or unplug/replug it?
    Anyone else seen this before?
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Can you provide more information?
    Like what side of the cable you were wiggling (PC or Monitor)?
    Do you have any tight bends in the cable?
    Is there a problem with your computer's VGA connection?
    Mar 2006
    Quote Originally Posted by tft_lcd_org View Post
    I'm wiggling the cable on the Monitor side and yes there is a tight bend in the cable due to the space provided in the dash.
    Also, the VGA on the PC is fine. I tested it with another monitor and I also tested the Xenarc using the onboard video and a seperate video card.
  1. Xenarc 700 issues detecting VGA signal
    By Outsider787 in forum LCD/Display
    Last Post: 07-28-2010, 03:16 PM
  2. Color Issues with Xenarc 700TSV
    By BhashaZ in forum LCD/Display
    Last Post: 07-09-2007, 12:37 AM
  3. display issues with xenarc 700tsv
    By KaOsTiK in forum LCD/Display
    Last Post: 06-25-2007, 06:40 PM
  4. Xenarc 700TSV No signal problem
    By camsgs3 in forum LCD/Display
    Last Post: 04-25-2006, 03:20 PM
  5. 700TSV no signal behavior
    By Crazy A in forum LCD/Display
    Last Post: 02-24-2006, 11:07 AM
