If you're going to mount it in the dash, you might be better off just taking it out of the case (perhaps partially) and having the buttons seperate.
Hey all, I have the DSCustoms VGA screen and found out it will fit almost perfectly inside my double din in my car IF it is turned upside down (because of the buttons on the front). I looked thru the docs that came with it but couldn't find anything...is there a setting that allows me to "flip" the screen so I can use the unit upside down (same option that flip-down screen have).
If not, does anyone know if the Epia 10000M video drivers allows you to flip the display (like NVidia drivers do)???
Thanks all!
Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
Car: 1993 Nissan Maxima, Black Emerald
You can always go download Pivot Pro ... lets you rotate the screen in 90deg increments. Pretty neat little prog...
-Capt.
PS. upside down screen you'd want to rotate 180deg . duh.
-Brad
83 mp320i
99 mp323i
_________
7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
Thanks for the info guys....I don't want to open up the screen cause I just got it and it has one of those nice little warranty stickers over one of the screw holes, maybe once the warranty is up I will go that route.
And thanks for the info on Pivot Pro, that may do the trick!
Cheers!
if you are using a nvidia gfx then you can change it there too
Pivot Pro Sux..
Multiple crashes.. Very very bad... Plus I'm not going to fork over 40 bones for the POS!
DOnottabuyatall...
