Its a transistor of some sort....You really need to post what the markings on it are, so we can work out which transistor u need.
pic stolen from http://www.jrok.com/hardware/lcd/lcd_panel_fun.html
I havent tried it at all after buying it from a member here, it seemed damaged since the "came loose" component was bent. I hooked it yp anyways and it worked like it should. then everything white on the screen became yellow and i saw that the part's one leg was loose...
Tried to get some pics with my crappy webcam but no luck, and then i saw smoke coming out of the back of the screen.... it was the resistor, it had gotten so hot the solder melted! I have no idea what that component is, and what it does (it has something to do with the color atleast)
anyone who knows what it is, would you please find me a replacement at http://www.elfa.se/en/ (only top names in the table of contents is in Swedish).
the resistor i guess I can find myself.
thanks
I lost it... but i's either:
1c
100
16v
or
1e
220
16v
could I just get two and change it if it's wrong?
Hello Jol,
Just opend mine and this is what i came up with.
condensator:
1F
220
16V
Mind that the blak side of it is the negative side.
resistor:
brown , black , black , gold
If i'm correct then this would be 2K ohm, but don't shoot me for it if i'm wrong. Maybe someone with more skills would know for sure.
PETER - THE NETHERLANDS - DEVENTER
sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
Thanks alot now i know what to get
That's a 10 ohm resistor, 5% tolerance. It's hard to tell if is a 1/2 or 1/4 watt resistor.
Thanks,mp3hombre That's a 10 ohm resistor, 5% tolerance. It's hard to tell if is a 1/2 or 1/4 watt resistor
Just got a hold on a meter and it says 9.9 so 10 it is.
From the size of the resistor i say its a 1/2W,
1/4W is smaller.
From the size of the resistor it looks like a 1/2 watt to me. Id put in a 1/2w it doesn't affect anything to go higher there just means it can dissipate more heat than a 1/4w.
The other is a surface mount capacitor. The dark on one side is the polarity label.
and it works again, thanks all.
The window on the crt is vnc.
I added a bunch of resistors instead of one 10, since I wasnt sure about the wattagetotal 10.8 ohm.
