Results 1 to 6 of 6
Thread: Cables
    Daz
    Daz is offline
    Jun 2003
    Cables
    Hey,
    I need a looooooooooong cable from the boot of my car to the dash for the screen - going to be using Composite out..
    Just to check, I just need a simple RCA - RCA cable, right? I've found one.. but it seems quite cheap for video and wondered if it would be ok?
    You can buy a cable with 3 RCA Males on each end or 2.. so it seems as if they are doing Video, Audio etc.. but I just wanna check.
    Thanks,
    Daz.
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    yes thats what you need. You also probably don't need the gold tipped rca cable. I'd just get like a 16 foot rca cable. You can buy just the video. Usually the dual ones are for audio.. both channels and the triple ones are for audio/video. No need to spend more cash when you don't have to.
    you can run rca cable like 50 feet without a problem.. i'm sure you don't have to run it that far.
    '98 Explorer Sport
    80% done
    Daz
    Daz is offline
    Jun 2003
    Well, they are both very cheap.
    $4.66 for 10metres Gold Plated with 2 RCA on each end.. not sure what that is in feet.
    Will probably end up buying this one.. if it'll work - 10metres should do it easily.. and give me some spare! Always best to have too much than not enough, hehe.
    Thanks,
    Daz.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    10 meters is 32.8 feet
    from http://www.uttyler.edu/mowings/Conversion%20factors.htm
    1 meter = 3.28 feet
    To convert meters to feet, multiply meters x 3.28
    To convert feet to meters, divide feet / 3.28
    TruckinMP3
    Read the FAQ!
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    get dual or triple shielded!
    Daz
    Daz is offline
    Jun 2003
    I got one which, doesn't say what it is.. so probably none..
