Mounting a touchscreen panel
Okay I have a 5.6" TFT screen and I'd like to add the digitalww 5.8" touchscreen membrane to it.
Whats the deal with actually fastening these? Are there limitations as to how they can be "sandwiched" between the case and the TFT etc, or hoe much overlap there can be or whatever?
Any experience people have of actually mounting these to screens (esp. any non-Xenarc screens which have already been proven) would be appreciated.
Basically want to sandwich it into this case: http://www.stuffandting.com/gallery/...jpg&menu=stuff
Cheers,
Ginge
Re: Mounting a touchscreen panel
The instalation is very straight forward, you just have make sure everything fits nicely. Here is the exact deimensions of the panel also take look at this instalation
If you have any specific questions - email me
Cheers,
Ginge
Re: Re: Mounting a touchscreen panel
Excellent, cheers! Just ordered one of these now, hopefully the taxman will go easy on me
One question, I'm fairly sure it will fit but if for example it needs modifying slightly to make space for mounting brackets etc, is the outer non-active area modifyable? For example will I be able to cut out a nick or shave a couple of mm off one edge?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
