I guess this is just a capactor (although it doesn't really look like one). There is always one between the inverters transformer and the CCFL connection.
One other thing; the standing capacitor next to the crystal looks like if it's popped. Perhaps you reversed the power connection? That easily blows capacitors you know...
white bream working on a trilogy: CARGO - UNIGO - MERGO
CARGO = the Car Computer
Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
Raw Wave
If thats the component thats gone wrong, then you might not get any backlight at all.
But if you are getting power into the other circuit and its working fine you should be able to see a very faint display on the screen....check carefully if this is the case...you need a very good eye for this.
If you can see some faint display then you know your inverter circuit or your backlight is gone.
Check the marking of this component on the PCB, if it say something like C then it is a capacitor, also check the marking on the component itself.
A normal SMD capacitor normally have both edge filled with solder pads. The body is normally brown. So i dont think it a capacitor...but who knows.
Check for light flashes on the screen as you connect or disconnect the power as well as any LED you can find.
Hope the helps
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
