Results 1 to 6 of 6
Thread: Dimensions of DSCustoms Screen
    Constant Bitrate leenas's Avatar
    May 2003
    Im thinking about getting this screen.
    http://www.dscustoms.com/products/ds700yyv.htm
    I have a quick question about the screen for those who have it. What are the actual dimensions of the screen, not the casing? Also there is a black surround. What are the dimensions of that?
    Can you remove the screen and safely move the buttons somewhere else or is that a big pain? Im asking cause if i get this screen i would want to make it flush. I have a bezel already which i can modify for the screen instead of going through making a fiberglass one.
    Thanks for the help!
    Jul 2002
    Alabama
    I'm getting one tuesday and I'm doing the same thing as you, so I'll let you know as soon as I can try it out.
    Constant Bitrate henkbliek's Avatar
    Dec 2002
    Netherlands
    Here's a pdf of the LCD panel that is supposed to be in the DS Customs screen: http://www.carpc.nl/download/edtcb18.pdf
    white bream
    working on a trilogy: CARGO - UNIGO - MERGO
    CARGO = the Car Computer
    Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
    Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    I just measured my screen. Those numbers in the pdf are accurate. I haven't yet taken my apart, but I'm also planning on a custom mount.
    Jun 2003
    Bay Area, CA
    Same plans
    I have the exact same plans as ou guys. Havent purchased the screen yet, but plan to very soon. Pleasr guys take pictures... if you can. i want to mount the screen flush in a double din as well.
    The only complicated part would be the bezel...
    Lets see how this goes... Please keep us updated.
    Jun 2003
    Waynesboro, PA
    I just placed my order today... it will be a little more interesting than a double din (darn Chrystler Jeep bezels), but should be fun. Be sure to use the link in dccustom's signature (in the forums here) to save $30 (it shows up when you check out).
