Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: How am I going to mount this DSCustoms screen flush in my dash? (Pictures)
  1. #11
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    1. make a wooden pattern of the opening you want to achieve. i would recommend MDF. remember to use proper breathing and eye protection as MDF is very nasty to your lungs when it is sanded or cut.
    1.1 test fit the screen into the wood opening.
    1.2 shape the face of the wooden opening to roughly what you want the final profile to look like. you can take off a bit more that you intend to, since you are going to cover it with fiberglass.
    1.3 secure the pattern in the opening. you can use wood or plastic bonded to the bezel cover from you car. basically you want to rigidly secure the wooden screen opening to the dash bezel.
    (note: i have specified wood to ensure you can secrew the screen into it. if you want to re-use the plastic case from the screen you can do that too.)
    2. use a piece of fabric to stretch across the gaps between the wooden opening and the bezel. make it tight, as this will dictate the basic shape of the fiberglass work. use a fleece type material, something that will soak up the fiberglassing resin.
    2.1 secure the fabric to the wood and the bezel. make sure it is tight.
    2.2 apply a coat of the resin to the cloth. follow the directions. let it dry. this will be the base for you to do your remaining fiberglassing.
    3. see the sticky thread relating to fiberglassing work. there is a nice tutorial posted that may be of some assistance to you.
    4. dont blame me if you screw up. i have never done this before. just read about it.
    5. sand the surface of the fiberglass and reapply materials as need to attain the surface shape you want.
    6. repeat sanding and filling as needed. i believe you can use bondo or some other surface filling material if you want to fill small gaps or air bubbles on the surface.
    (note: you WILL have to paint the entire bezel. the fiberglass will be some color that does not match the bezel. just warning you that you will have to paint the entire thing to make it look uniform. or you can cover it with a vinyl or leather material.)
    best of luck
    ~mike
    edit...
    here is the fiberglass thread
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
  2. #12
    Jul 2002
    Alabama
    So when I attach the fleece to the wood bezel and the double-din bezel, it's permanent, right? Like i just fiberglass it in place?
  3. #13
    Jul 2002
    Alabama
    mp3z24,
    I tried what you said to do, but it won't work. If you look at the pic I posted at the beginning of the thread, there is a border around the screen. Thus, using wood, I can't make the screen flush in a wood frame without that screen border being visible, which would just be ugly. So, if you look at my post like 3 posts up, my idea is to make a fiberglass mold of the bezel that came with screen since it slopes down and covers up that ugly border around the screen. I can then chop off the sides of the fiberglass mold so that it fits in the dobule-DIN. What do you think? Will that work?
  4. #14
    Apr 2001
    Chicago Suburbs
    personally, i dont think that making a mold of the screen border/frame will work. you have to think about actually mounting the screen to something substantial.
    if you want to use the plastic frame as a pattern, you are going to have to construct a clay (or other material) mold, then you are going to have to use the frame to get your mold pattern in the clay, allow it to dry, seal it, coat it with mold release agent, lay up the fiberglass including some mouning post for the screen...etc. the process is pretty long and you are going to have to buy a lot of supplies for just a simple project.
    when i say make a wooden frame, it doenst have to be a 2x4 piece of wood or anything huge like that. you can use something like 1/2 MDF. just as a base for the screen and the fiberglass to attach to.
    the basic point that i am trying to get across is that you are going to have to incorporate something into your fiberglass that allows you to attach the screen to the bezel. what you are suggesting is 100% do-aable, however, i dont know if it will be the best option considering the extra work that will probably be required.
    oh, and yes what i am talking about IS a permanent installation. but, if you build another frame to go behind the opening in the dash bezel, you can make the fiberglass piece removeable. kinda like a fiberglass insert that fits in the opening.
    ~Mike
  5. #15
    Low Bitrate The Undertaker's Avatar
    Jul 2003
    The Netherlands
    System in progress:
    New install in progress...
  6. #16
    Jul 2002
    Alabama
    Ok, I think I finally understand what you mean mp3z24. Here is what I've done so far, I haven't finished cutting the hole for the screen but you can see where I've started
    Here it is from the back
    After I cut the hole, I plan on sanding down the inside edges of the wood frame so that it meets the lcd screen flush, like I wanted, so you can't see the green border around the lcd screen. I'm then going to stretch fleece from the inside edge of the wood frame and hot glue it to the edge of the audio bezel (the woodgrain thing) (see photoshopped pic below) The fleece will be at an angle and the screen is going to be recessed from the audio bezel.
    I can then put the fiberglass resin on the fleece and apply mat as needed. Does this sound like it will work now?
  7. #17
    Jul 2002
    LA
    That link to the custom mold is just siiiiiiiiiiiick........
  8. #18
    Jan 2003
    Ruston, LA
    It will work just fine making a mold, the thing is he will have to use something other than fleece, like some fiberglass cloth, multiple layers. That would be plenty rigid.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #19
    Mar 2003
    Gainesville, FL
    hey guys me and my friend both did a similar install by molding in the lcd bezel into the double din space with bondo. . check it out here
    http://protege5.com/vbb225/showthrea...ight=lcd+bondo
    http://protege5.com/vbb225/showthrea...threadid=24407
    elemental59437 did the same setup as i did and actually he helped me out on it. . . .
    mine is actually finished and my post isn't updated but it looks great
  10. #20
    Jul 2002
    Alabama
    That looks awesome traitorhound. Unfortunately, my LCD bezel doesn't fit in the double-DIN like yours. It's just a little bit too big. Man this is a pain in the *** . . . hopefully it will all work out.
