Results 21 to 30 of 35
Thread: How am I going to mount this DSCustoms screen flush in my dash? (Pictures)
  1. #21
    Jul 2002
    LA
    Man, another sick mold....
  2. #22
    Jul 2002
    Alabama
    Here are some pics to show where I am. As I understand it, I can just stretch fleece from inside the wood frame and hot glue it to the audio bezel to cover the gap, and then add fiberglass resin and mat. Is this all correct?
  3. #23
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    hmmm... thats a pretty small gap that you are working with... shouldnt be that hard to do.
    one thing to consider. if you are attaching the fleace to the plastic bezel, you may want to epoxy it to the inside lip of the double din opening. i say this because if you hot glue it, it might not be strong enough, and if you glue it to the front of the bezel, you will have to sand the crap out of it to get it to look right.
    now that i have seen the progress you have been making, i have another route that you may want to take...
    instead of using fiberglass, you may want to build up the height difference between the wood and the plastic with thin strips of wood, kind of a stair-case of wood strips to make the transition, and then cover it with bondo or something similar. then you can sand or file the bondo smooth. the neat thing about this approach, is that you can make the whold lcd monting piece seperate of the dash bezel. if you are careful with your work, you can probably get a good fit, with just a minimal break in the surface between the dash bezel and the lcd mount.
    plus, if you want to get rid of the screen someday, you wont have to buy a new bezel for the car.
    also, think about embedding screws or bolts in the wood part, so that they are sticking out the back of the wood. this will give you a solid point to mount the screen onto.
    ~Mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
  4. #24
    Jul 2002
    Alabama
    In progress shots for anyone who cares . . .
  5. #25
    Jan 2003
    Ruston, LA
    coming along I see
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  6. #26
    Jan 2002
    Excelent Work! Just make sure that you sand it very smooth and get a good coat of paint on it. Looks Great!
    "A4 Quattro. Rocket Science."
  7. #27
    jol
    jol is online now
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    we care, keep the pics coming
  8. #28
    Maximum Bitrate Skippman's Avatar
    Mar 2002
    St. Louis, MO
    Looking smooth. Wish I had the dash space for that. Supid 2K3 redesign.
    Stereo:Alpine IVA-D900 Head Unit | Alpine PXA-H510 DSP | Boston Pro Component Speakers Upfront | Boston Rally Rear Speakers | 2 Polk 10" Subs in the Trunk | Phoenix Gold Ti900.7 Amp
  9. #29
    Jul 2002
    Alabama
    Here it is after cutting off excess fiberglass
    Now I have a couple of questions. My next planned step is to add Bondo filler to smooth it all out. This is what I should do, right? If so, do I need to sand down the fiberglass any before adding the Bondo? Also, I kind of scratched up a little of the woodgrain on my audio panel near the fiberglass. Would it be OK to extend the Bondo filler to cover up this area?
  10. #30
    Jan 2003
    Ruston, LA
    no sand, just add bondo
    extend bondo.. probably be fine
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
