huh?
I guess you can?![]()
Is it possible to use a VGA (640 x 480) resolution to watch DVDs and connect to a regular PC, assuming the proper interface to the LCD???
huh?
Its not clear from your post...do you want to use a computer monitor to watch a DVD player? Or do you want to connect a DVD player to your computer?
KG6OQD
www.americansandassociation.org
I want to be able to play DVDs in my car and i have a VGA 640x480 res LCD. I also want to be able to connect the same LCD to a pc and use it as the monitor.
If it has a standard vga connector on it, it will work fine.
Have you even tried to connect it?
Remember you need a DVD player to be able to see DVD's on it.![]()
Never been connected. Dont have a DVD player yet. I was just wondering if The DVD format or output had a minimum resolution requirement to view them..
some of the original players actually force the res down to 640 x 480. Come to think of it, Im almost certin windvd does this on my toshiba lap top (6 months old 1.8 g)
Standard TV res is 720 x 480
