Have you tested the S-video output with a display you know works?
Typically, the video will auto detect a screen is hooked into the tv-out and use that as a primary display. But this may not be the case here. You may need to enable tv-out as your primary display. Also, some cards will only use Tv-out at low resolution such as 640x480 or 800x600.
LinkBack URL
About LinkBacks
