NITS... CR... & Viewing Angle...Values for success
Just wanted to ask around, people whom already installed LCDs inside their vehicles. What value for Brightness (nits), Contrast Ratio (CR), and Viewing angles have you used thats led to an LCD with good viewing quality during a bright sunny day and dark nights....
i was using the 6.5" TFT from earthLCD with touchscreen and it was perfectly sunlight readable with 300nits if i remember it well, even when the sun was shining directly on the touchscreen!. although at night i had to switch it off. i now have a wiring plan to hook up a potentiometer to it so i can dim the light, but as of last saturday my display seems to be broken :-(
greets
pascal
Your saying it was too bright at night?
Thanks for the reply
yeah, too bright, but only at night.. too bright means, it is so bright that it is very distracting and it makes it hard to see everything outside the car, plus everybody who passes can see your face being lit up by the display ;-)
but there is a software tool on this board which helps you to get it darker.. darker never really is a problem.. only brighter is hard to get.. so i would'nt bother (except for if you only use it at night heeh) ..
plus: most inverters support a dimming function.. with mine it is pretty simple.. just attach a 10k potentiometer over two pins and you can dim the backlight.. just check the tech-sheet for your inverter...
current
2001 Chevy Tahoe
Carputer MK 3
- Mobo out of Shuttle Barebone System
- AMD Duron 1300
- 7" Lilliput
- Opus Powersupply
- MediaCar
earlyer installs
1996 Ford Explorer Carputer MK 2
1997 Subaru Impreza GT Carputer MK 1
Excelent... So 300 nits should do.
another little remark... since one of the two light-tubes in my screen are not working anymore (see my other recent post) i am now driving around with approx. 150 nits.. (half of the 300 i'd have with both i guess.. ) ... and 150 is good to bi driven at night.. not too bright but on the upper limit i'd say... during the day it is rather dark. when the sun shines driectly on it you can't really read it anymore..
so another easy solution to make your screen darker would just be to switch one of the two tubes off.. but this is a very ugly solution, since your display is then bright on one side and dark on the other.. (but at night it wasn't that clear.. only if you look very close, so it will work as a "last" solution :-) )
cheers
pascal
current
2001 Chevy Tahoe
Carputer MK 3
- AMD Duron 1300
- 7" Lilliput
- Opus Powersupply
- MediaCar
earlyer installs
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
