Lilliput 669GL Touch Screen Controller Issue
Hi all,
Trying to set up my Lilliput 669 monitor. Currently using it with HDMI for video and USB for the touch screen. Image works fine and the computer can see the touch screen fine.
With Windows 7's default touch screen drivers (auto installed) the touch screen axis are inverted (change in x results in mouse movement in the y and vice versa) even after calibration. Not a problem, I'll install different drivers. I've tried both older touchkit drivers as well as the latest eGalax touch drivers and both install fine. I can calibrate and the test drawing feature lets me draw fine, works rather well.
But when I try to use the touch screen to press something in Windows or Centrafuse it won't register mouse movement or clicks. Windows shows 'USB Touchscreen Controller(Universal)' as a mouse device under devices which seems right as afaik it's emulating a mouse. I've also tried many different restarts, clearing old drivers and everything I can find/think of so thought I'd ask here.
Anyone got any ideas? The only other thing I can think of is a compatibility interference so will try a fresh install on another computer later on.
Running Windows 7 x64.
Cheers,
Dan
