Hi
sounds like something is wired badly at the tail lights... (doesn't really explain why your going into video 1 though ) do you have a trailer hitch? sockets on these are notorious for causing issues when they get old,also check the silly snap connectors they use were they splice into the main harness...failing that check all the connector's in the boot area for the tail lights...also I found if I had the camera earth at the boot the quality of the video was worse than running without an earth..then again my camera was real cheap![]()
LinkBack URL
About LinkBacks
