Results 1 to 6 of 6
Thread: Help find missing cables to touchscreen controller
    Low Bitrate FockMasterDan's Avatar
    May 2008
    Westerville, Ohio
    So a while back (a couple years maybe) when I first started getting into this I ordered a 7" touchscreen overlay kit as a way to get started tinkering on the cheap for my display. I'm finally putting it together and have figured out way after the fact that they left out two crucial cables, and I'm having trouble finding a place to order them without just ordering a new controller.
    I also need to drivers for it, as my kit is missing the disc too.
    Here is one of them that I need, so there is a solution.
    http://shop-on-line.tvielectronics.c...b095014dd2a161
    The other is this one, but this site is in the UK (and doesn't even ship to US).
    http://www.e-screen.co.uk/index.php/...ler-to-pc.html
    So I guess really I just need a source for the second one. I would even be fine with just the connector for the controller and I could make the USB cable.
    Computer is in the car, but in a very "raw" install right now.
    Worklog - here
    Variable Bitrate rray's Avatar
    Apr 2012
    SF Bay Area
    The USB cable looks like it has a micro JST connector like this one: EBAY ITEM 181032597288
    This company makes most of the controllers for those ebay touchscreen kits, so their drivers might work:
    http://www.touchkit.com/Drivers.htm
    May 2008
    Westerville, Ohio
    The ebay link didn't work, but from searching micro JST connector I found it.
    http://www.ebay.com/itm/Micro-JST-PH...item1c2e88ac88
    After sorting through digikey I finally found it through there for pretty cheap. I'm going to try that and see if it works, if not I'll order the connector and build one but I should be fine. Even if it's the wrong pin out I can re-pin the connector easily.
    http://www.digikey.com/product-detai...026-ND/1625791
    I had found it listed on so many touch controller kits, but they all used different part numbers that didn't transfer over and never called the connectors any kind of standard name. This should have been easy, but took a lot of digging.
    Worklog - here
    Apr 2012
    SF Bay Area
    I went through it several weeks ago when I was trying to find those micro JST connectors for my touchscreen, not knowing what they were called. I also had trouble with the motherboard header pins and connectors until I found they were called 2.54mm Dupont connectors. I ended up ordering a special dupont pin crimper so I could make up my own cables, and found that it also crimps micro JST pins too.
    May 2008
    Westerville, Ohio
    Well the connector on the digikey cable is the wrong one. It looks remarkably similar in the pictures but is slightly larger than the JST. The quest is back on, but I do know it's a micro JST from you guys so that is quite helpful. Worst case I'll build my own cable.
    Worklog - here
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Did you get this working?
    If not I will send you the cables you need for 12.00 shipped.
    Quote Originally Posted by HiJackZX1 View Post
    This system was supposed to be a quick, cheap throw together that has now exploded into a budget blowing mess.
  1. Replies: 2
    Last Post: 04-01-2010, 09:21 AM
  2. Anyone know where i can find a lilliput touchscreen controller?
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 10-13-2007, 03:45 AM
  3. missing lilliput cables
    By dstryr99 in forum LCD/Display
    Last Post: 09-25-2006, 06:10 PM
  4. M1-ATX missing some cables - help
    By BobDowne in forum Power Supplies
    Last Post: 06-21-2005, 04:01 AM
  5. Where can I find parallel cables over 10 feet?
    By sleddog4 in forum General Hardware Discussion
    Last Post: 12-16-1999, 06:41 PM
