Results 1 to 7 of 7
Thread: LCD screen as a cluster replacement non obd2 car
    Jun 2005
    Hi all I'm hoping someone can help, if this is in the wrong section can it be moved to the relevant location :-)
    Ok so I have just finished configuring up my car pc for my Nissan stagea (skyline estate)
    I have just thought about bringing it up to controll my gauges with is being a 1996 car it's quite old looking on the dash and as the car is undergoing lots of work the though of swapping the boring cluster out for a LCD really appeals to me lol
    I saw the centrafuse sdk demo of what can be achieved although I can't find anyone that has actually done it
    Can anyone point me in the right direction
    Currently the dash has the following
    RPM
    SPEEDO
    RIGHT INDICATE
    LEFT INDICATE
    PARK
    REVERSE
    NEUTRAL
    DRIVE
    FIRST
    SECOND
    FUEL
    WATER TEMP
    ENGINE CHECK
    SEAT BELT
    DOOR OPEN
    HIGH BEAM
    OVERDRIVE OFF/ON
    4WD
    SNOW
    ABS
    REAR HEATER
    ODOMETER
    BRAKE WARN
    EXHAUST OVER HEAT
    OIL
    CHARGE
    Now all the lamps on the dash are just 12v on or off Don't you just love the old styles lol
    On the rear of the unit the speedo
    The rpm, speed. All ave the following markers
    Sin +
    Sin -
    Cos +
    Cos -
    The fuel and water have the following
    GND
    COS +
    COS -
    It looks like I could get 2x 7" screens in there or I might go for 1 8" as it would be easier on single screen I guess
    Anyone able to help
    Cheers
    Andrew
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Being that it's 96 I doubt it has obd2 port, Most of the idiot light stuff is simple just tapping wire for voltage. Temp,presure,fuel, exhaust could be put on analog if you can get voltage readings like cold/hot full/empty and doing the calculation. Speedo you could get from GPS but not sure on accuracy, dead zones, tall buildings, overpasses ect. Just my 2 cents SNO
    RPM OBD port
    SPEEDO OBD or GPS
    RIGHT INDICATE Phidget Digital In
    LEFT INDICATE Phidget Digital In
    PARK Phidget Digital In
    REVERSE Phidget Digital In
    NEUTRAL Phidget Digital In
    DRIVE Phidget Digital In
    FIRST Phidget Digital In
    SECOND Phidget Digital In
    FUEL Analog reading of sensor and doing voltage calculation
    WATER TEMP Analog reading of sensor and doing voltage calculation
    ENGINE CHECK OBD port
    SEAT BELT Phidget Digital In
    DOOR OPEN Phidget Digital In
    HIGH BEAM Phidget Digital In
    OVERDRIVE OFF/ON Phidget Digital In
    4WD Phidget Digital In
    SNOW Phidget Digital In
    ABS Phidget Digital In
    REAR HEATER Phidget Digital In
    ODOMETER OBD or GPS
    BRAKE WARN Phidget Digital In
    EXHAUST OVER HEAT Analog reading of sensor and doing voltage calculation
    OIL Analog reading of sensor and doing voltage calculation
    CHARGE Analog reading of sensor and doing voltage calculation
    I am partial to Phidgets brand stuff but it can be any board using analog-digital input/output
    Mar 2006
    Colorado, but Canadian!
    Many of those gauges are resistive and cannot be treated purely as an analogue input. I do this with my boards and a system called MiMod. It is the only true system that can achieve this on a reliable level.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2005
    Quote Originally Posted by 2k1Toaster View Post
    hi can you tell me more about these boards
    im quite good with wiring and locating connections on the plus side the rear of the factory cluster has everything labelled up to help with the work
    Jun 2005
    Ok so I have looked a bit more into this and it looks like the fusion system is what I'm likely to go for
    By my calculation (limited as this is theory Bassed at the mo) till further testing
    I have as standard 26 inputs which equates to 2 brains
    Most of those 26 are idiot lights and are going to be 12v on/off filament lamps as standard (old school lol)
    21 lamps on current display for warning from looking at the cluster it looks like they are all direct 12v to power them on will double check this
    The remaining inputs are variable so providing I can locate the correct voltage to raise and lower I should be ok....
    do I need to use either of the following as well
    4 Chanel input isolator
    Or
    Frequency to voltage converter
    What's the best way to tackle the odometer unit I currently have a converter chip installed to change the speedo. From kph - mph
    In theory I can power the spare dash up and get the readings for the variable units using potentiometers to drive a different current into it
    Mar 2006
    Quote Originally Posted by rabster View Post
    Or
    For the 21 dummy lights, a simple resistor divider will work. If you want to use a board, then the 4 channel isolators will work well. You would need 6 boards, for 24 possible inputs, 21 used. You might find out that you want others too like knowing when the IGN is on versus ACC mode versus just off. That sort of thing. These are the easiest.
    For the resistive sensors, you will need to match a top or bottom resistor along with the sensor itself and get the curve. This is not easy to get a good reading and not blow up the brain.
    For the voltage sensors, a simple voltage divider may be neccessary, but it is relatively straightforwards. Again an input on the isolator board can work too, but it is non-linear when it goes through the isolation, so it is no longer just a multiple of your reading, it is an exponential equation and requires math. Once the math is figured, it is pretty easy and no work needs to be done, but it can be difficult at first.
    For the odometer, tachometer, and speedometer, these are not that simple. The frequency board may work, but may not. In the cars that I have helped do this too, usually there was a lot of modifications needed and a good understanding of the system in there.
    Basically, the system we have in place to do this is called MiMod. There is a lot of custom hardware that I made for that system that could be sold individually if EVInstruments (the owners of MiMod) allow it. You would have to buy it from them because it is their intellectual property now. The MiMod system is really a great system and does exactly what you want easily. Also it is a dedicated embedded platform just for the gauges. Remember on a CarPC that flash drives and updates can render a system unstable since there is a possibility for contamination. There is also a possibility of general flaky-ness depending on your build. You do not want to be driving down the road when your gauges go blank.
    In the past I would just say a simple, "no you cannot use the Fusion Brain for replacing your gauges". However after working with Troy at EVInstruments to develop the MiMod sensor hardware, I am convinced that is the way to go for safety and features. There is nothing on the market even close to it. We were at SEMA this year, and nothing even close.
    Check out this car, see if this is close to what you were thinking: http://www.chevyhardcore.com/news/gr...d-of-tomorrow/
    I would contact Troy at EVInstruments first about getting some of the hardware: http://www.evinstruments.com/Inquiries.aspx
    Mention the "odometer board", "tachometer board", and the "MiMod HP Motherboard with Daughterboards", he will know what you are talking about.
    If you do not want the full system from him, at least you might be able to buy the hardware.
    Mar 2006
    http://www.youtube.com/watch?v=g7zvGmL0y2c
    That is an EV with it. The new term for what you want is the "Ahead Driver System".
  1. Replace Gauge Cluster with LCD Screen?
    By lukeescude in forum General MP3Car Discussion
    Last Post: 06-18-2012, 10:18 PM
  2. Cluster Replacement
    By Joel Maxwell in forum LCD/Display
    Last Post: 05-20-2012, 05:01 AM
  3. Replies: 14
    Last Post: 01-12-2011, 10:38 PM
  4. OBD-II/CAN Replacement Computer Instrument Cluster (Working!)
    By necros in forum Software & Software Development
    Last Post: 02-04-2010, 03:58 AM
  5. Guage Cluster Replacement?
    By jeffbeckhudd in forum General MP3Car Discussion
    Last Post: 12-22-2006, 05:49 PM
