Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Tablet as a touchscreen monitor
    Oct 2006
    Hello! I've not seen this particular subject discussed here via a search but please forgive me if it has.
    I'm in the process of building a car PC and would like to use an existing Windows or WebOS/Android tablet as the touchscreen monitor. The screen quality is very good on both and I would have the added benefit of being able to take it with me and use it outside of the vehicle. The primary use for the car PC would be to play audio files/playlists through my existing sound system and also use GPS functionality.
    The tablets and PC have Bluetooth and WiFi for communication but my preference would be the former (using a PAN), to avoid having to set up a wireless ad hoc environment in the vehicle. However, I'm not a network expert and there probably is a way to do this without too many issues. Since I don't want to stream the audio through the tablet (as most RDP software does) I'm having a difficult time finding an application that will allow control of the PC from the tablet (as a touchscreen) but still send the audio from the PC to the sound system.
    I checked out Splashtop but that only supports WiFi. Given the explosion of technology lately this should be an easy problem to solve, but clearly I'm missing something. Any ideas?
    Thanks!
    Oct 2006
    I would really appreciate some input. Thanks!
    FLAC SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Just find a 12v or 5v router and install in your car. That would be my best suggestion. SNO
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    That's very similar to what I have planned. I'm going to be dropping a linux PC in the trunk as my music "tank" along with an wifi access point if I can't get a supported card under linux easily running as the access point. Linux will run SubSonic on it in a jukebox style mode, and I'll be using my iPhone and/or other tablets to control playback as well as stream content to them for other passengers if they don't like my tunes.
    I like your idea, like to see where you take it.
    Tidder
    Try RevFE
    Oct 2006
    Quote Originally Posted by Tidder View Post
    Yeah, it's looking like the WiFi router is the way to go. I'm considering the D-link DAP-1350, due to its small size and versatility. Splashtop allows the audio to be streamed from the server (car PC) as well as the client (tablet), which is what I want. Any other router options would be appreciated.
    Will keep you posted as I move forward with this!
    Sep 2003
    New Mexico, USA
    I once had an access point about that size, but it had the ability to be powered off USB. I'll see if I can dig it up, I think it was an encore device.
    EDIT: Actually, here's an interesting one I just came across... http://www.kanexlive.com/myspot
    Tidder
    Try RevFE
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Mar 2008
    these are sold on ebay and have DD-WRT preinstalled (I bought a couple - they work):
    TP-Link TL-WR703N
    Oct 2006
    So are these devices used as an ad hoc network or do they assign an IP address via DHCP? My car PC does have a Gigabit port, so it would be no problem setting up the wireless security parameters. Sorry if I'm missing something!
    Sep 2003
    New Mexico, USA
    With DD-WRT you could configure it with DHCP and more than likely could setup the wired NIC as local LAN so it basically turns it into an AP with DHCP capabilities. I'm gonna have to get a couple and check it out.
    Tidder
    Try RevFE
  1. Is there any way to use a tablet as monitor?
    By thedocta in forum General Hardware Discussion
    Last Post: 10-30-2012, 11:47 PM
  2. Tablet as display monitor??
    By ral6639 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-23-2012, 09:35 AM
  3. Reflective Fujitsu tablet as a daytime monitor
    By RipplingHurst in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-07-2010, 12:42 PM
  4. Please Help - Qbe Tablet PC touchscreen problem
    By Scrapez in forum LCD/Display
    Last Post: 05-30-2003, 08:32 PM
  5. FS: touchscreen, pen tablet, lp3 mp3 decoder, gps
    By tbdombrosky in forum Classified Archive
    Last Post: 09-19-2002, 01:38 AM
