Results 1 to 4 of 4
Thread: change AV when i do reverse
    Newbie alcool_puro's Avatar
    Oct 2005
    I have CTF400-ML and this monitor don't have automatic system for rear cam (wire to connect 12v).
    And I need to change the AV1 when i do reverse.
    I could connect the monitor micro-switch (to change AV) to the relay, but would not work because if the trigger on relay stay connect more 1 second, the monitor turns off.
    I need a solution that the micro-switch turns on only 1 second, when I have the 12v.
    Dec 2006
    istanbul
    there are timer relays you can use, called TON or TOFF.
    another cheap solution, connect a serial capasitor to the relay if you want it to be energised for a short while when power is applied.
    or connect a capacitor in paralel with the relay if you want it to release later after power is disconnected.
    Jan 2008
    how good are you with circuits? you could use a 555timer wired up in monostable operation:
    http://freespace.virgin.net/matt.wai...y/pinouts/555/
    Oct 2005
    I managed to do with 2 relays and 1 capacitor. The 2nd relay coil is supplied with capacitor, and only stays on about 1 second.
    Tks
  1. Reverse Camera Trigger Question - Reverse Light has separate ground
    By Mears in forum General Hardware Discussion
    Last Post: 09-26-2010, 04:23 PM
  2. Reverse
    By nuvodido in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-14-2009, 02:53 PM
  3. Reverse Cam Guidance.
    By ax_foley in forum General Hardware Discussion
    Last Post: 12-05-2007, 03:58 AM
  4. reverse cameras
    By dexy in forum LCD/Display
    Last Post: 05-24-2005, 04:45 PM
  5. reverse camera
    By Grunge-Futtoch in forum MediaCar
    Last Post: 09-03-2004, 12:06 PM
