Can't from USB, as USB can only provide 5v.
Tap into a HDD molex for 12v.
I had a carpc install and have since switched to a tablet install, but i do have this Lilliput monitor left over. I would like to mount this inside of a computer case i have and was wondering if there was a way i could take the existing power cable for the monitor and solder it to a usb cable for power?
If not is there a way to do it on one of the 12 volt rails?
I was looking through the forums and could find anything on powering one with usb.
any help is much appreciated![]()
Never accept STOCK equipment.
or you can connect it to plain-ole automotive power off the main battery to get it to work.
My 2001 Mitsubishi Eclipse GT:
"The Project That Never Ends"
more projects then time!
Led Skyline Tail Lights--100%
High Power Led Reverse Lights--100%
Led third brake light--100%
Led front turn signals--0%
HID retro--100%
If you are mounting it in the computer case, tap the 12v rail of your computer power supply.
