Results 11 to 20 of 30
Thread: Capacitive Touch Panel Help Please
  1. #11
    Jan 2012
    Quote Originally Posted by Masejoer View Post
    As would I. A 9-10.1" would be perfect for my vehicle. LED backlit IPS at 1280x720 or higher would be nice. I think we're within a year away from getting something aftermarket using ips/cap tablet screens. Some offerings on eBay are CLOSE but not quite there.
    After we get something decent, then we'll be wishing for OLED...
    You can get a 10.1" Capacitive touch panel, and I believe I saw a 10.1" 2560x1600 panel out there somewhere. It's basically what's in the Nexus 10.
  2. #12
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Quote Originally Posted by eugenweij View Post
    http://njytouch.com/ctp.htm
    various sizes , resistive, capacitive , and a few other technologies available , low price but good quality (I have one and it works like a charm)
    Really?
    Which one do you have?
    NJY does not sell USB Capacitive panels unless you want to have a custom panel made. And, they want 3000pc minimum order for that.
    Their capacitive panels are I2C interface. Without the HID descriptors from them (they don't have them) you can't even get those to work with an I2C enabled device.
    Quote Originally Posted by HiJackZX1 View Post
    This system was supposed to be a quick, cheap throw together that has now exploded into a budget blowing mess.
  3. #13
    May 2012
    Grandville, MI
    But does win7/8 recognize them as a touch screen or as a mouse?
    I was going to use Win8 on my CarPC until I found that my egalax driver is only seen as a mouse and not a touch screen so the swiping doesn't work.
    I have a screen I bought that uses a 4 wire multi touch USB egalax driven touch.
    Would you possibly have a replacement touch controller that would use a driver that is compatible with win8 gestures?
    Rodney
  4. #14
    May 2010
    Detroit, MI
    Quote Originally Posted by redheadedrod View Post
    Rodney
    Can you send me more information on that display? or maybe some pictures of the touch connector, controller, etc?
  5. #15
    May 2011
    Salem, OR
    Mimo has a 10" capacitive.
    I have a 669 capacitive from tft_lcd and its great. X and Y axis are inverted and you have to revert them every time it starts up... Kinda a pita
  6. #16
    May 2010
    Detroit, MI
    Quote Originally Posted by Jesus Freak View Post
    I have the cure for that issue. Please email me for instructions. Thank you
  7. #17
    May 2011
    Salem, OR
    Quote Originally Posted by tft_lcd_org View Post
    Thanks, I'll get everything setup tonight and should be able to call tomorrow. Thanks for the quick reply and customer service!
  8. #18
    May 2011
    Salem, OR
    Thanks again, the screen is working in the correct orientation, very accurate and crystal clear.
  9. #19
    May 2010
    Detroit, MI
    You are welcome. Glad you like the display.
  10. #20
    Aug 2006
    Portland, OR
    Any idea as to what needs enabled in the Linux kernel config for the touch controller?
    **EDIT: Ok I'm getting much closer. You may want to let people know that the digitizer you use is a Atmel maxTouch device. To enable in linux kernel, enable: CONFIG_TOUCHSCREEN_ATMEL_MXT=y
    I will be testing this and will return with my results. Looks to be promising, may have to update the kernel driver code to the latest Atmel has made avail but may not need to.
  1. Transflective + capacitive panel?
    By Nillaz in forum LCD/Display
    Last Post: 09-03-2012, 06:34 PM
  2. Replies: 3
    Last Post: 06-30-2012, 06:20 PM
  3. need a 8.9" capacitive touch panel
    By Jallath in forum General Hardware Discussion
    Last Post: 04-22-2012, 05:06 PM
  4. Replies: 3
    Last Post: 08-22-2010, 05:50 PM
  5. Capacitive touch panel for 11.6" LCD?
    By impreziv in forum Input Devices
    Last Post: 02-28-2010, 10:43 AM
