Page 11 of 30 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 300
Like Tree2Likes
Thread: 1280 x 800 ips capacitive panels
  1. #101
    req
    req is offline
    Mar 2012
    camo.b, this is in the comment thread on the install page;
    Quote Originally Posted by Dr. Ace Jeangle Mod Banu 6 months ago
    No, LG display accept only exact 1280x800 resolution. You will get black screen for others resolutions. You should wait until we release new board with LVDS scaler - this one will work with any HDMI source.
    http://www.chalk-elec.com/?p=1576
    so? please reply
  2. #102
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Yes.I'm having problems finding a device in my house that outputs 1280 x 800.but my laptop does but I can get it to see the lvds adapter.so I can't set the screen res.....
  3. #103
    Nov 2011
    Touch drivers load on the laptop and touch works very well.I have to find my other video card for my desktop tonight (it has hdmi out) and fit it.I will test again on the desktop.hoping there arnt any problems with the new screen.....
  4. #104
    Constant Bitrate FockMasterDan's Avatar
    May 2008
    Westerville, Ohio
    Hmm the laptop that I hooked mine up to put out the correct resolution no problem. Good luck getting that figured out.
    Computer is in the car, but in a very "raw" install right now.
    Worklog - here
  5. #105
    Nov 2011
    yep I was thinking it was strange that the laptop didn't register a second digital display like it does with my plasma tv......
  6. #106
    Nov 2011
    Quote Originally Posted by req View Post
    you tried this on a windows 7 or 8 computer with a video card that supports 1280x800? they said if the resolution was not supported it would display black - and you HAVE to push 1280x800 or it wont work.
    did you try (on the computer) to manually change the resolution? does it need video drivers updated?
    Yep I understand about the lg panel only accepting 1280 x 800...
  7. #107
    May 2008
    Westerville, Ohio
    Alright well I started the physical install today. Fiberglassed a bezel from scratch over the dash in order to accomodate the huge screen. I just did phase 1, but next I'll be trimming, shaping, and creating the opening/mounting for the climate controls below the screen.
    It's still a bit early, but this was the risky part. To get the screen mounted since it doesn't have any kind of bezel it comes with I taped and waxed it up and fiberglassed right over it. I hate using the real parts but sometimes there's no better way.
    Worklog - here
  8. #108
    Nov 2011
    I'm looking at the same setup..was thinking I will flush mount the touch screen with my glassed up dash.could probably double side tape it in place with mine and the facia panal that will hold the screen is 1/3 of the dash and very easly removed.my last 7"screen was duble side tapped in and was actually very hard to remove.think I had to cut it off then peel both sides of the tape off
  9. #109
    Nov 2011
    So I now have my chinatobby driver board and my 10.1 touch panel lcd.just did a test run with them both mixed together and success all works very well.I just need to solder the usb cable to the lvds connector on the back of the lcd panel and I'm good to go....so I now have a 10.1 ips multitouch panel with hdmi/vga(this i need)and auto reverse camera input.perfect setup I thinks!
  10. #110
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I just hooked up my Chinatobby 8" panel and am surprised how nice it is for the price. The hdmi controller seems pretty good but the touchscreen is on a desperate module.
    Sent from my SCH-I535 using Tapatalk 2
  1. Replies: 1
    Last Post: 02-20-2011, 02:13 PM
  2. my CNX-1280 blew up
    By pushing4wardbac in forum Power Supplies
    Last Post: 12-10-2006, 10:24 PM
  3. Carnetix 1280 enough ??
    By markbuts3 in forum Power Supplies
    Last Post: 06-27-2005, 07:57 AM
  4. P 1280 AND an inverter to power my carpc, make sense?
    By Will Albers in forum General MP3Car Discussion
    Last Post: 05-24-2005, 12:50 PM
  5. carnetix cnx-1280
    By Gibson99 in forum Power Supplies
    Last Post: 01-17-2005, 02:08 AM
