Page 19 of 30 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 300
Like Tree2Likes
Thread: 1280 x 800 ips capacitive panels
  1. #181
    Jan 2014
    I sent them email, message through their website over a month ago and no response. Are these guys even still in business, or they just don't have anymore product? Any alternatives for a 7" capacitive for win 8?
  2. #182
    Constant Bitrate txspazz's Avatar
    Feb 2008
    TEXAS
    According to this latest update the most recent delays have an upside. New products and a faster turn around. http://www.chalk-elec.com/?p=1859
  3. #183
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Oh that is some good news...particularly with the hid cap touch 7"....who will be the first to order?
  4. #184
    May 2012
    Grandville, MI
    This is cool news...
    Also don't forget that the member tft_lcd_org also does custom panel stuff as well. He just converted my 7" screen from resistive to capacitive and helped me figure out what screen would fit in my truck.
    Would be cool to see what panels they do present though since I will be replacing another screen.
  5. #185
    Jan 2014
    I got one of the 10" screens, looks good, but took months to turn up. Where as chinatobbys turned up in a week.
  6. #186
    Nov 2011
    Quote Originally Posted by chug1 View Post
    Post some pics when your up and running!!
  7. #187
    Jan 2014
    The 7" open frame panel on the chalk elec website is 161.9 X 110.2 mm. I have a double din Metra brand trim plate which has an opening that measures 172 X 99 mm. Im only 1/2 cm too short on top and bottom (~1cm total), the opening in the kit is big enough for the actual screen as the bezel is probably not smaller than 15mm total according to the technical drawings (screen is 95.55 mm tall). In that case I can prolly just trim the BACK of the trim plate opening with a dremel without touching the front.
    Width wise I'll have 3.5mm on one side and 6.5mm of bezel on the other side according to the technical drawings. However I will still be about 5mm short on either side. Will that much space look bad? If so how can I fix it? Is there a guide on here on how to make this small mod?
  8. #188
    May 2011
    beijing,china
    I think I can help you, haha
    8”inch 192.8*116.9
    9"inch 210.7*126.3
    10.1“inch 235*143
    if 8’inch you can use ZJ080NA-08A this LCD 500 ccd 1024*600 win8 metro OK
    if 7”inch you can use HSD070PFW3-C00 this lcd 600cdd 1024 600 win8 metro OK
Size:  151.9 KBName:  8寸AA.jpg
Size:  73.5 KBName:  IMG_20140607_230127.jpg
  9. #189
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Dear MP3CAR members, I have bought the same model of PCB and IT DOES NOT WORK.
    Please wait a confirmation from a test from a forum's member before buying
    Hi fuchengwu
    From which company are you?
    I had problem with such touch screen.
    The problem seems to come from the PCB Version 2.
    Your 2 first pictures show the V1 PCB which i tested and it worked.
    But your third picture show Version 2 which is faulty.
    here is a comparison :
    Which version would you provide?
    Please give details.
    Brice.
  10. #190
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Quote Originally Posted by fuchengwu View Post
    8”inch 192.8*116.9
    Hi Fuchengwa, I bought the "HDMI+VGA+2AV Control board+8inch ZJ080NA-08A 1024*600 Lcd panel+Touch Screen" and installed in my dash. Everything works well, but I wanted to make it brighter so sunlight would not wash out the screen. When sunlight is on the screen I cannot see it.
    Do you have a brighter screen in the same size available?
    wrxcv likes this.
  1. Replies: 1
    Last Post: 02-20-2011, 02:13 PM
  2. my CNX-1280 blew up
    By pushing4wardbac in forum Power Supplies
    Last Post: 12-10-2006, 10:24 PM
  3. Carnetix 1280 enough ??
    By markbuts3 in forum Power Supplies
    Last Post: 06-27-2005, 07:57 AM
  4. P 1280 AND an inverter to power my carpc, make sense?
    By Will Albers in forum General MP3Car Discussion
    Last Post: 05-24-2005, 12:50 PM
  5. carnetix cnx-1280
    By Gibson99 in forum Power Supplies
    Last Post: 01-17-2005, 02:08 AM
