Results 1 to 3 of 3
Thread: screen flicker
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    screen flicker
    anyone know the cause/solution to fix a flickering screen when you turn the volume up. ? i have a intel D510M0 board hooked up to a four channel AMP. when i turn the volume up the lilliput screen kinda flickers... like lines appear. i dont know how to describe it. a video might be better......the screen is powered by the PC power supply.
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Raw Wave
    Nov 2009
    Bad connection - unplug & replug video and power cables.
    Bad GND - check GND connections and screws etc.
    Shared noise or insufficient wire gauge if sharing the same +12V distribution or GND wires, or if in close proximity (eg, amp power to video power or signal).
    After that it's flimsy screen construction (mechanical vibration) or maybe voltage dips/noise.
    Aug 2007
    Queens, NYC
    thanks, i do have the CarPC sharing the same connections as the AMP. I will try to seperate the connections eventually. Its not bad but looks tacky when the music is playing loud.
    CarPc
    Project "Driver"
    Planning [99.9%]
  1. Replies: 1
    Last Post: 03-24-2008, 06:18 PM
  2. G4 and screen flicker?
    By RipNRun in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 07-05-2007, 07:51 PM
  3. Liliput: Flicker, flicker, flicker.. Dead
    By bobs987 in forum LCD/Display
    Last Post: 01-05-2007, 01:59 AM
  4. Screen Flicker. PLEASE HELP!
    By mazda3uzr in forum Power Supplies
    Last Post: 11-09-2004, 09:35 AM
  5. Screen Flicker
    By johnram in forum LCD/Display
    Last Post: 06-25-2001, 11:33 AM
