Results 1 to 9 of 9
Thread: Help relocating buttons on DSCustoms/*enarc screen
    Low Bitrate vladilen's Avatar
    May 2003
    I am working on installing a DSCustoms DS700YYV into my dash. The opening in my dash is not tall enough to accomodate the full monitor enclosure. I can mount the screen without any problems, but the controller board has to be mounted at a slight angle.
    This means that the buttons on the controller board will not be accessible. While this is not really a problem, I would like to be able to use the mode and power buttons just in case I expand the system.
    Has anyone wired external buttons to this controller? Any other suggestions?
    Thanks in advance.
    Phase I of project
    May 2003
    Bump. Help? Anybody?
    Newbie rally1's Avatar
    Jul 2003
    Huntington Beach, CA
    Have you tried yet?
    I would think you would just need to wire an additional switch accross the circuit where the existing switch is.
    You will need a momentary SPST switch.
    May 2003
    I will try it tonight.
    Will try to connect a SPST to the circled points. I plan on using clips for testing and then soldering if it works.
    Any words of wisdom will be appreciated before I actually try this.
    Jul 2003
    The only thing I would say is that those appear to already be connected.
    Use a meter to test continuity, I think you'll find they are, it sure looks like it.
    Newbie loakster's Avatar
    Nov 2002
    Los angeles
    hi I am trying to do the same exact thing. Go to google and type in shuttle + xenarc. That will take you to a webpage of a guy who installed a xenarc screen in a shuttle xpc. He re-located his buttons. Their is alot of info their also on how to take the unit apart without turning it into a pile of junk!
    let me know how the re-location is going gzjunk@msn.com
    My project has taken forever some times i wish i bought the tm-701L instead of the xenarc, but i think the end result will be worth it.
    Jul 2003
    nice one
    http://www.talix.com/
    a great page
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    The circled conections are the same point. Use the point from the upper row and one from the lower row.
    Here is a pic where I rewired these buttons to work with TM-701L Buttons:
    buttons removed from the board:
    I will have more pics for you tomorrow.
    May 2003
    Thanks. I tried it your way earlier in the evening and it worked great.
    I will not desolder the existing buttons - that is way outside of my abilities.
    I'll probably put a glob of hot glue on the button to prevent it from being pushed accidentally and solder wires leading to a new button on the back side of the board.
