Results 1 to 7 of 7
Thread: Lilliput screen blinks on/off when on Video1 with backup camera connected
    Dec 2007
    Mohnton, PA
    I replaced my custom unit last March with a Mp3car direct fit Lilliput (I forget whether I have EBY701 or 629GL), but I added a backup camera and added the reverse switch. I get 12V when its in reverse, but it won't switch automatically, and if I manually go to Video 1 where the connection is made, the screen blinks and I get an image from the camera for a split second. It might come on every 5-10 seconds but immediately goes back off.
    I had this problem with a backup camera last year after I did this, and I thought the camera was bad, so I sent it back and just recently bought a new one. It's the PAL camera that Mp3car sells. Is the signal not compatible?
    This is really annoying since I have gone through the effort to route the wires and mount the camera cleanly.
    Further, I can't even access the hidden menu on this LCD. I've typed 588998 and hit the menu button on the monitor itself and I think I'm starting to wear it out.
    Dec 2007
    Mohnton, PA
    I connected my video camera to the input on the Lilliput and it actually works. So do I have another bad camera or is something else going on?
    The camera says PAL and the Lilliput accepts PAL input.
    Dec 2007
    Mohnton, PA
    Mp3car store support is terrible, so I am relying on you guys. I powered my backup camera with a 12V brick inside my house and hooked up to my TV and it works fine. My video camera connects to the Lilliput fine, so I know the input is good. Is it possible they are selling a backup camera that is NOT compatible with the Lilliputs they sell?
    The camera says the system is PAL, which I would expect for Video 1 or Video 2 of the EBY701, so what gives.
    Elsewhere
    PAL is a video format used in Europe and other locales.
    I'm not 100% certain, but I believe PAL and NTSC don't play nice together.
    If the Lilliput & functioning camera are both NTSC, then the PAL camera won't work. I'm speculating, but that may be one possible problem.
    How about the Wiki?
    Dec 2007
    Mohnton, PA
    Quote Originally Posted by DarquePervert View Post
    The Lilliput claims to be PAL.
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Here is the store's service pledge:
    mp3Car Customer Service General Guidelines
    Most general customer questions have been answered in the mp3Car Store FAQ, please take a look before submitting a ticket.
    To better serve all mp3Car customers in a timely manner, all customer service inquiries should be submitted to [email protected]. Please make sure to provide an order number along with your inquiry (when applicable), otherwise we will be unable to access your order records.
    Should you require an immediate change to your order or feel that your issue requires immediate attention, please also use [email protected] as the contact email address and title your inquiry as "Urgent" and your ticket will be given priority.
    1. We are committed to timely customer support. We will respond to your customer service inquiries within one business day. Please allow two business days for technical support tickets.
    2. We will do our best to correct mistakes. In the case of a mistake made on our end, we will attempt to go above and beyond to right the situation in an expeditious and respectful manner.
    3. Communication is key. When something out of normal store operations occurs, we will go above and beyond to keep the customer informed about their order, RMA, or service inquiry.
    Did you follow this or post on the store forum? Here: http://www.mp3car.com/mp3car-products-store-mp3car-com/
    I would expect that they would at least monitor those forums.
    Dec 2007
    Mohnton, PA
    The website is broken and I can't even file an RMA. To make things worse, I was poking around last night and found the EXACT same camera for $14 on Amazon, a tad bit lower than the "sale" price of $34.95 on Mp3car. I have sent them several emails but I'm not getting any assistance.
  1. Backup camera on Lilliput UM-1010/C/T
    By venfayon in forum LCD/Display
    Last Post: 03-03-2013, 05:23 PM
  2. Replies: 4
    Last Post: 03-02-2012, 12:10 AM
  3. Lilliput 809GL does not like my backup camera
    By dmurray7 in forum LCD/Display
    Last Post: 11-15-2011, 11:49 PM
  4. Replies: 10
    Last Post: 07-21-2008, 05:53 PM
  5. PIC Backup Camera Source Switcher for Lilliput
    By EricE in forum LCD/Display
    Last Post: 11-03-2006, 06:09 PM
