Hello,
Kinda new here. For some reason i can't see the diagram for the 3.3 volt mod. I just bought on Datalux LMV10R on ebay and would like to mod it. Could you please email me the picture of the circuit.
Thanks.
Originally Posted by Trottingwolf
Hi all someone pointed out that it looks like there is a cap on the v-sync from my diagram. There isnt. The cap is on the 5V line and not the V-sync. I will update the diagram and make it a little bigger.
Hello,
Thanks.
Sorry I've been away for a while. I got real busy at work.
Not sure why the pic I posted is not there anymore but I will put it up again. I also took some pictures of the inside of the screen before I sold it and will see if I can get those up here somehow.
That helps so much!!! YOU ARE THE MAN!!!! I can pick up the parts on the way home from work and get started on upgrading the monitor.
I'm looking forward to getting an ITX computer, probably a Epia-M 9000 and a 40 GB HD. Just hope a 60 Watt DC-DC converter can handle it.
Thanks!!!, I'll wait for those pics, i'm in the middle of a war right here, I bought it a week ago & and I can't put it to work. I hope this solve my problem.
HB
Works like a charm! I had to order 10 of one of the parts, so I have 9 "sets" of the parts needed, if you want, I will mail the IC and the capacitor out for $4 shipped (cheaper than shipping through digikey, and I only had one monitor to repair).
I cut the yellow (vsync) and white (hsync) wire going to the connector on the VGA to TFT converter board. The IC was spliced in between the wires, I bent all the pins that needed to be connected to each other. The grounds were all combined from the tantalum capacitor that ran underneath it. A lead was spliced, and that ground was connected to the same area on a screw (you can't miss it). I hotglued the whole thing to the wire bundle
For 5v, I tapped "C8", the center pin on the cable running to the inverter. It's a red wire on my LMV10R. That new tapped wire now has a 3pin male/female connector on it on each end so I can remove the backplate just like normal (I used some fan adapter cable I cut up).
Thank you Trottingwolf (and your EE friend)!
91 Stealth RT/TT
CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
Display: Lilliput 7" Touchscreen
I found the email with the part numbers from digikey, here are what I have 9 of each available.Originally Posted by Vineet Singh
1 10 296-1605-5-ND IC HEX INVERTER 14-DIP DATALUX_IC
2 10 1210PHCT-ND CAP 50V .1UF AXIAL CERAMIC Z5U DATALUX_CAP
91 Stealth RT/TT
